[ht] switch on/off the outflow boundary condition as a time function
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   6 Replies   Last post: June 19, 2017 6:17am UTC
Jalu Naradi
Jalu Naradi
June 13, 2017 4:24pm UTC
I am simulating a heat transfer in porous media [ht module].
I want to switch on/off the outflow boundary condition as a function of time.
For example:
Outflow 1 ON if t< 4 [d]
Outflow 1 OFF if t>= 4[d]
Outflow 2 ON if t>= 4[d]
Outflow 2 OFF if t< 4[d]
Thank you,
Best Regards
Lasse Murtomäki
Lasse Murtomäki
June 15, 2017 6:05am UTC in response to Jalu Naradi
Re: [ht] switch on/off the outflow boundary condition as a time function
Use the Heviside function. Like this:
(1-flc2hs(t[1/d]-4,0.01))*(your function)
BR
Lasse
For example:
Thank you,
Best Regards
Henrik Sönnerlind
Henrik Sönnerlind
COMSOL Employee
Sweden
Moderator
June 15, 2017 7:39am UTC in response to Lasse Murtomäki
The Outflow condition is, with respect to temperature, identical to a Thermal Insulation (the default boundary condition).
Thermal Insulation (and Outflow) are actually boundary conditions 'doing nothing'. They have no input, and add neither constraints nor weak contributions.
So the question is what you really want to achieve here. What should happen during the time when it there is not an outflow?
Henrik
Reply  |  Reply with Quote  |  Report Abuse
Jalu Naradi
Jalu Naradi
June 15, 2017 2:03pm UTC in response to Henrik Sönnerlind
Henrik
Thank you for your response.
I'm simulating a reoriented potential mixing of geothermal reservoir. The reservoir is modelled as a 2D circular with 8 wells on its circumference with 45 degree distance between the wells.
The well in the model will act as injection well and production well.
For example: Well 1 is injection well at time 0-4 days and will be production well at time 16-20 days.
This way, geometrically I only have 8 wells but they will act as 8 injection wells and 8 production wells.
The problem is I cannot set all production wells as an Outflow. (If I do this, all injection wells will overridden by production wells)
What should happen is:
at time : 0-4 days --> injection well 1 and production well 1 active, another wells are deactivated.
at time : 4-8 days --> injection well 2 and production well 2 active, another wells are deactivated
And this scheme will continue until 32 days.
I tried to attach my mph file, but the site always say that the file extension is error.
Thank you very much for your help
Jalu Naradi
Jalu Naradi
June 15, 2017 2:05pm UTC in response to Lasse Murtomäki
BR
Lasse
Hi Lasse,
Thank for your advice.
But I think I cannot implement your answer because I cannot put anything on the outflow boundary condition.
Jalu Naradi
Jalu Naradi
June 17, 2017 11:09am UTC in response to Jalu Naradi
Hi Henrik,
My above question can be simplified as below:
If I want to set a boundary as an outlet, what is the node that I can choose as an alternative of outflow node?
Thank you in advance,
JN
Henrik Sönnerlind
Henrik Sönnerlind
COMSOL Employee
Sweden
Moderator
June 19, 2017 6:17am UTC in response to Jalu Naradi
There is not built-in setting for switching between different types of boundary conditions withing a single study step. You can however use the methods described in this blog post:
www.comsol.se/blogs/how-to-mak...onditional-in-your-simulation/
Henrik
Rules and guidelines
