Interpolation Function Help
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   14 Replies   Last post: February 15, 2017 6:19am UTC
Erin  Koksal
Erin Koksal
July 18, 2011 1:33pm UTC
Good Morning,
I'm having trouble using COMSOL's interpolation function, and I was hoping someone might be able to help. I'm trying to load data from a tab-delimited text file. I've followed the instructions in the COMSOL user guide on interpolation functions, however I get the following error when I click "plot":
"Internal error in mesh initialization.
-Plot: previewplot1 (Surface)
-Function: int1"
Additionally, when I try to solve the model I get the following error message:
"-Feature: Compile Equations: Stationary (sol1/st1)
-Error: Internal error in mesh initialization."
When I disable the interpolation function, COMSOL successfully solves the model.
The input data used for the interpolation function was a velocity distribution exported from a previous solution surface. It has the following structure:
% x y z myfun1
0.005164328 0.094835672 0.2 0.098519135
0.015894103 0.087647192 0.2 0.511590803
0.015569986 0.095339275 0.2 0.22689919
0.006197193 0.083275657 0.2 0.312314232
0.005469283 0.016082383 0.2 0.2672031
0.004733427 0.004733427 0.2 0.081290304
0.012546053 0.01240331 0.2 0.43510989
0.015707096 0.004896326 0.2 0.232560416
0.027164381 0.094602393 0.2 0.368319369
etc.
A very simple flow model demonstrating the problem is attached, along with an excel version of the data I'm using. I'm a new COMSOL user, and any advice would be greatly appreciated.
Thank You!
Yoann  Many
Yoann Many
July 19, 2011 7:32am UTC in response to Erin Koksal
Re: Interpolation Function Help
Had the same issue with an imported data .txt file, and it has 2 parameters while yours seems to have three of them. The only thing I figured was to reduce the number of parameters to 1, and no more error messages.... But I guess in your case it's quite out of the question.....
sorry I can't help you
Lichun  Wang
Lichun Wang
August 14, 2012 7:33pm UTC in response to Erin Koksal
Me toooo! Once I used interpolation function with three arguments, it will pop out the error message. Hope someone expert will answer this question soon.
Nagi Elabbasi
Nagi Elabbasi
Certified Consultant
Veryst Engineering
August 15, 2012 6:37pm UTC in response to Lichun Wang
One of your variables always has the same value of 0.2. It seems that this is not acceptable for COMSOL. If you change some numbers to say 0.3 it works. Alternatively you can remove that variable completely from the function.
Nagi Elabbasi
Veryst Engineering
Magnus Ringh
Magnus Ringh
COMSOL Employee
Sweden
August 16, 2012 12:38pm UTC in response to Nagi Elabbasi
As Nagi explains above, an interpolation function of three arguments does not work well when one of them is a constant value (it is a degenerated case). Perhaps you want to treat this as function of two variables (arguments), neglecting the values in the third column. You can then import it without having to modify the data file but specifying, in the settings window for Interpolation, that there are 2 arguments, and, under Functions, that the position in the file for the function values is 2. That means that COMSOL treats columns 1 and 2 as the argument values, and the second of the following columns (that is, column 4) as the column with the associated function values. Column 3 is then not used.
In this particular case the data is in an Excel file, which the Interpolation function does not support in a general way, but you can save it as text file, which is a supported data format. Furthermore, the values in the file seem to use a decimal comma rather than a decimal point. Replacing commas with points in the text file it is possible to import it as described above and plot the interpolation function as a surface plot.
Magnus Ringh, COMSOL
Reply  |  Reply with Quote  |  Report Abuse
Xu Gong
Xu Gong
October 10, 2012 11:02pm UTC in response to Nagi Elabbasi
Hi, Nagi:
I have a question for the interpolation function, can you help me? Thanks.
My function has two arguments p and e instead of coordinates x and y, and the form is:
G=f(p,e)
So, I create the spreadsheet as:
% p e G
1e6 0.5 2e6
2e6 0.6 3e6
etc...
But the COMSOL always assume to be coordinates as argument. How to fix this problem?
Thanks a lot.
Xu
Xu Gong
Xu Gong
October 10, 2012 11:05pm UTC in response to Magnus Ringh
Hi, Magnus:
G=f(p,e)
% p e G
1e6 0.5 2e6
2e6 0.6 3e6
etc...
Thanks a lot.
Xu
Jeff Hiller
Jeff Hiller
COMSOL Employee
USA
Moderator
October 11, 2012 12:49pm UTC in response to Xu Gong
Hello Xu,
The Discussion Forum is primarily meant for customers to assist each other. To request support from COMSOL support personnel, please email support@comsol.com.
Francesco Travascio
Francesco Travascio
May 23, 2013 6:43pm UTC in response to Jeff Hiller
I have a quick question on the interpolation functions used a boundary conditions.
I am working on a 3D model with PDE weak form. I need to introduce a boundary condition for a weak contribution that is tabulated in a file. This is
f=f(t) meaning that the only input argument is the time.
I have a text file built in this way:
% t force
0 1
0.1 3
0.3 7
etc.,
When I introduce this function as boundary condition I receive the following error message:
Failed to evaluate variable Jacobian
- Variable: int1
-Geometry: 1
-Boundary: 4 8
-Feature: Time-Dependent Solver 1 (sol/t1)
-Error: Failed to evaluate variable Jacobian
can anybody help me?
thanks
Sepideh Ramezani
Sepideh Ramezani
February 12, 2015 10:26am UTC in response to Francesco Travascio
I have same problem, I want to impose an interpolation function and my data are like below:
% x y hh
90.603 53.779 -0.40248
84.429 93.007 -0.31846
92.494 133.702 -0.27818
110.658 216.016 -0.36048
127.878 296.939 -0.51878
But when I want to plot them, I am confronting with this error that: "Mesh interpolation failed".
Do you have any idea why I am getting this kind of error? Is it related to negative values of my function?
Is it sth happening in mesh?
Many thanks in advance for your help.
Sepideh
Usharani Rath
Usharani Rath
February 13, 2017 6:30am UTC in response to
Hiii,
I am a beginner to COMSOL 5.2.
I am getting some problem while incorporating the interpolation function into my model.
The function is described below.
Pint(t) = 1, t<= 0.00007s,
decreases linearly to zero, 0.00007s<= t<= 0.00009s
0, t>= 0.00009s.
Can anyone help me out how to do the same.
thank you.
Jeff Hiller
Jeff Hiller
COMSOL Employee
USA
Moderator
February 13, 2017 6:53pm UTC in response to Usharani Rath
Usharani,
Can you be more specific about the problem you're encountering? It should be a straightforward use of interpolation functions.
Usharani Rath
Usharani Rath
February 14, 2017 6:54am UTC in response to Jeff Hiller
Hiii Jeff,
The issue is when I am plotting the interpolation function by putting the values of t and F(t) in the local table, the plot is like a step function only. It does not take into account the values provided in the local table.
Usha
Gunnar Andersson
Gunnar Andersson
COMSOL Employee
Sweden
February 14, 2017 8:04am UTC in response to Usharani Rath
Preview plots of functions by default use 10000 points (in the latest version, 5.2a), so they aren't guaranteed to capture dynamics on all scales. Note that this also holds for the solver: Make sure to set up the time list to capture the dynamics, or else the solver might step past it.
Usharani Rath
Usharani Rath
February 15, 2017 6:19am UTC in response to Gunnar Andersson
Thank you Mr. Andersson.
Rules and guidelines
