model.param.get does not return complex values
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: November 28, 2011 6:15am UTC
Emi Kawamura
Emi Kawamura
November 27, 2011 10:43am UTC
I set a parameter to a complex value by:
model.param.set('v1', 4.5+j*2)
However, when I try to access the parameter later by
model.param.get('v1')
All I get is
4.5
I am using comsol4.2a and matlab 2011a on a 64 bit linux machine.
Does the error occur when I am setting the parameter value or when I am accessing it.
In other words, is 'v1' correctly set to the complex value, and it is just the model.param.get that is not
working properly?
Or, is it model.param.set which is not setting 'v1' correctly?
I would appreciate any help.
Thank you,
Emi
Ivar Kjelberg
Ivar Kjelberg
November 27, 2011 7:55pm UTC in response to Emi Kawamura
Re: model.param.get does not return complex values
I'm not sure you can retrieve the comlex value in one call, have you tried to recall twice with a real() and imag()
Emi Kawamura
Emi Kawamura
November 27, 2011 9:20pm UTC in response to Ivar Kjelberg
No, the model.param.set does not work if you set a parameter to a complex number.
Currently, I am getting around this by turning the complex value into a string and
setting the parameter to that string.
Example:
v1 = 4.5+j*2.5
v1String = num2str(v1);
model.param.set('v1', v1String);
Then when I call
I get the correct value:
4.5+j*2.5
So, I guess to pass complex values to model.param.set, you need to convert it to a string first.
Emi
Ivar Kjelberg
Ivar Kjelberg
November 28, 2011 6:15am UTC in response to Emi Kawamura
Then I think it's worth to get that confirmed by "support". I find it somewhat astonishing, but OK, I hardly use matlab now with V4
Rules and guidelines
