Measure voltage difference between 2 points on model
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: January 20, 2017 2:59am UTC
Vijay Ramakrishnan
Vijay Ramakrishnan
October 9, 2012 7:57am UTC
Dear Sir,
I want to know if there is any way i can insert a voltage probe or electrodes in my comsol model, to measure the voltage difference between two points in the model.
Thanking you in advance,
Vijay
John Schmidt
John Schmidt
October 9, 2012 5:25pm UTC in response to Vijay Ramakrishnan
Re: Measure voltage difference between 2 points on model
Vijay,
I believe all you have to do is (say you are in a 2D model) add two Domain Point Probes (right click on Definitions under [FileName] > Model(#) > Definitions). In one Point Prove Expression, set it equal to V; in the other, set the expression equal to V - mod1.ppb1 (or whatever the probe is). Then you can plot mod1.ppb2 as a function of whatever you like. I believe that this will get you what you want. There may be other ways to do this using a line, and then finding the potential distribution along that line. There is a very detailed explanation of this in the help documents as well.
Good luck,
John
Ivar Kjelberg
Ivar Kjelberg
October 9, 2012 6:48pm UTC in response to John Schmidt
Hi John
As you say, its better to use a boundary than a 2nd order (down) entity (as a point or edge in 3D), as you might have singularities on calulating flux around a singe point/vertex/edge
Sahil Asija
Sahil Asija
January 20, 2017 2:59am UTC in response to Ivar Kjelberg
Hi John
Rules and guidelines
