Angle of incidence, RF modul, Comsol 4.2a
Topics: 4.2a, RF Module
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   5 Replies   Last post: November 19, 2012 4:58am UTC
Samuel Roj
Samuel Roj
November 3, 2012 11:31am UTC
Dear All,
I have issue. I have one metal block on substrate, and I want to illuminate it but at some angle (picture).
One half sphere is substrate, one half air.
Now I want to apply x polarization, scattered field.
I have two cases, first when substrate is also air, and second when substrate is glass (with index refraction ns).
In the case when substrate is air I applied equation: E0*exp(-j*(emw.k0*x*sin(phi)+emw.k0*z*cos(phi)).
In the case when substrate is glass I applied equation: E0*exp(-j*(emw.k*x*sin(phi)+emw.k*z*cos(phi)).
Or maybe in second case I have to write:
(1-sign(z))*E0*(-j*2*pi*x*sin(phi)/Lambda-j*2*pi*z*cos(phi)/Lambda)/2 +
+ (1+sign(z))*E0*(-j*2*pi*x*sin(phi)*ns/Lambda-j*2*pi*z*cos(phi)*ns/Lambda)/2
Tell me please for any of these equations are they correct.
Thank very much in advanced.
Attachments:   Doc1-15970.doc
Yuanpeng Wu
Yuanpeng Wu
November 17, 2012 4:17pm UTC in response to Samuel Roj
Re: Angle of incidence, RF modul, Comsol 4.2a
I want to know that you use the scattering boundary condition or the Port to input the light, and how do you set the wave direction or the propagation constant
Samuel Roj
Samuel Roj
November 17, 2012 4:53pm UTC in response to
I used scattering boundary condition, but I am nor sure that I understoood second question about equation.
Yuanpeng Wu
Yuanpeng Wu
November 18, 2012 5:44am UTC in response to Samuel Roj
I think you can type E0*exp(-j*(emw.k0*x*sin(phi)+emw.k0*z*cos(phi)) in the "incident field", or you can just set kx=k0*sin(phi), ky=k0*cos(phi) in the "wave direction"
Nikola Bralovic
Nikola Bralovic
November 18, 2012 2:42pm UTC in response to Yuanpeng Wu
I am not sure about second way. I used first way: E0*exp(-j*(emw.k0*x*sin(phi)+emw.k0*z*cos(phi)). I always use incidetn field, not wave direction.
Cheers
Yuanpeng Wu
Yuanpeng Wu
November 19, 2012 4:58am UTC in response to Nikola Bralovic
Hello
Do you find that if you use the same incident field for example E0*exp(-j*(emw.k0*x*sin(phi)+emw.k0*z*cos(phi)), but select the different boundary as the input, the wave direction is different, do you know why?
Cheers!
Rules and guidelines
