how to get the average values on parallel channels
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   7 Replies   Last post: November 18, 2012 12:07pm UTC
Yuanhai Su
Yuanhai Su
November 15, 2012 11:53am UTC
Hello everybody. Now I simulate the hydynamics of the distributor with parrallel channels. I want to get the mean velocity values in the middle of each channels. I try to use the 'cut plane' on the postprocess, but this operation will create the surface for all parrallel channels. So it doest not get the value for each channel. The geometry is like the attached document.
Thank you for your help!!
Attachments:   geometry.docx
Ivar Kjelberg
Ivar Kjelberg
November 15, 2012 2:18pm UTC in response to Yuanhai Su
Re: how to get the average values on parallel channels
I beleive the easiest is to cut your geoemtry so you have some useful internal boundaries at each inlet/outlet for all your U shapes, then youcan select the different boundaries. The geoemtry is slightly more complex, the model too, but it's far easier to work and postprocess like that
Yuanhai Su
Yuanhai Su
November 15, 2012 2:27pm UTC in response to Ivar Kjelberg
Mr. Ivar, Thank you so much! I will try it.
Yuanhai Su
Yuanhai Su
November 15, 2012 2:34pm UTC in response to Ivar Kjelberg
Mr.Ivar,
I try it again. I used the section of 'derived values" after creating the surface. Unfortunately, I can not get the independent values for each channel. I only get the mean value for the parrallel channels. Maybe I misundertood you? Thank you.
Yuanhai Su
Yuanhai Su
November 17, 2012 10:20pm UTC in response to Yuanhai Su
Could every one help me on this issue. Thank you!
Ivar Kjelberg
Ivar Kjelberg
November 18, 2012 9:41am UTC in response to Yuanhai Su
If you use a "cut plane" in the Data set, you need to combine in many bolean values to get the local avarages (and you should not use the average operator, as this will average over the full area).
Threfore, in such cases I split the pipes in the geometry as sections od domains with defined interna boundaries where I want to measure some value. The in the Derived Variable section you can select one boundary after the other and ask for the local average of any flux or variable value
Yuanhai Su
Yuanhai Su
November 18, 2012 11:35am UTC in response to Ivar Kjelberg
Dear Mr. Ivar
Thank you! You mentioned that I should split the whole geometry with internal boundary. It seems a good strategy. Do you have other solution to this issue if the geometry is not created as separated parts? Because now I had finished the simulation on the whole geometry.
Ivar Kjelberg
Ivar Kjelberg
November 18, 2012 12:07pm UTC in response to Yuanhai Su
you can add a few workplanes and apply some surface/rectangles that cut your domain (even if your main geometry is imported from a CAD system) then the default "union" mode of the Geometry Finish node should decompose your domain/BCs accordingly.
Not that this might well change the domains ID's so you must carefully go through all nodes to check these apply to the correct domains/boundaries, as COMSOl might get mesed up in the internal entity ID data base
Rules and guidelines
