Temperature mapping with Model Coupling
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   4 Replies   Last post: December 6, 2012 12:51am UTC
Joseph Williams
Joseph Williams
December 3, 2012 7:34am UTC
I wish to generate temperatures in a model and subsequently map the temperatures them to a similar model in a different study. The two models will have the same geometry. However, the model will be moved to a new location in the second study.
I generated the simple attached case to practice and discovered that I must be missing something.
Can someone point out my mistake?
Joe
Attachments:   PRACTICE_50.mph
Ivar Kjelberg
Ivar Kjelberg
December 3, 2012 3:18pm UTC in response to Joseph Williams
Re: Temperature mapping with Model Coupling
check the mapping operators to map one model variables to another.
You can have several models and copy the geometry or several physics in the same model (less evident for debugging) separated via the solvers
Joseph Williams
Joseph Williams
December 3, 2012 7:37pm UTC in response to Ivar Kjelberg
Hello Ivar,
Thank you for getting to me and pointing me in the right direction. I think I see what I have to do for different model locations and I decided to repeat the practice without moving the second model, just to make sure I understood the procedure.
The result is shown in the attached case and it looks as if I failed to correctly map temperatures. In fact it appears that I somehow loaded 0K as the initial temperature in my second model.
Can you point out where I am making some fundamental mistake and what I need to do for this practice case.
Thanks again,
Joe
Attachments:   PRACTICE_60.mph
Ivar Kjelberg
Ivar Kjelberg
December 4, 2012 8:00am UTC in response to Joseph Williams
you have an easier way to model your case
0) you can have several studies under the same model
1) you can select the initial conditions of study 2, based on values from study 1
3) you can also enable and disable BC from the study node, hence making complex linked studies
In this way your values are better controlled and the transfer of variables from one "model" to the next one is far easier
Joseph Williams
Joseph Williams
December 6, 2012 12:51am UTC in response to Ivar Kjelberg
Dear Ivar,
Your suggestion is great. It will same me lots of time.
Joe
Rules and guidelines
