Current/Charge conservation in AC/DC
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   1 Reply   Last post: December 10, 2012 9:40am UTC
Arun
Arun
December 10, 2012 9:20am UTC
My model has several layers of domains having different conductivity and permittivity. I want current to be conserved in each domain independently. At present, I choose current conservation node for respective domains.
After solving, the volume integration of space charge denisty on all domains (i.e. the net charge) is zero. However, each domain is not independently conserved. Is there a way to specify independent charge or current conservation to each domain?
Arun
Ivar Kjelberg
Ivar Kjelberg
December 10, 2012 9:40am UTC in response to Arun
Re: Current/Charge conservation in AC/DC
from my understanding, one or several current conservation nodes does not separate the items, by default all internal boundaries are in "continuation mode". If you want to have "isolation between the domains, you need either to use assembly mode, or probably easier add electrical isolation / shielding between your layers on the BC's
Rules and guidelines
