Running a specific Study node using batch
Topics: 4.4, output
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: September 30, 2014 2:01am UTC
J
J
January 10, 2013 4:44pm UTC
I would like to run a specific Study node (suppose I have a model with 2 or more Study nodes) using batch commands. Normally I write something like
comsol -nn 8 -np 8 batch -inputfile input.mph -outputfile output.mph -batchlog batch.log
Does anyone know which additional command I should issue to be able to select a specific Study node to run?
J
Josh Thomas
Josh Thomas
Certified Consultant
AltaSim Technologies, LLC
January 10, 2013 9:54pm UTC in response to J
Re: Running a specific Study node using batch
Doctor J,
Simply type:
comsol -nn 8 -np 8 batch -inputfile input.mph -outputfile output.mph -study <study tag> -batchlog batch.log
You can even specify which parameters to solve for and their values from the command line if you wanted using -pname and -plist.
Check out pgs 95 and 96 of the Installation and Operations Guide for more COMSOL Batch Commands.
Hope that helps.
Josh Thomas
Josh Thomas
Josh Thomas
January 10, 2013 9:58pm UTC in response to Josh Thomas
Oh, if you don't know the <study tag>...right-click on the main Study node and select Properties from the list. The Settings window will give you the tag. For example, std1 or std2, etc.
Josh Thomas
Weijia Cui
Weijia Cui
September 30, 2014 2:01am UTC in response to Josh Thomas
What if I want to get output of one node?
For example, I want to know the temperature of a node and I know the tag of this node is tag1.
What command should I type for this?
THX
Rules and guidelines
