mesh error: how to find the point?
Hi to everybody,
I'm new to Comsol and maybe my question can result a little bit stupid.. in this case please forgive me!
I'm tring to mesh a 3D spring pipe (diameter 5.5 mm) with some small holes (diameter 1 mm). Everytime the software gives me this kind of error:
"Failed to insert point.
Coordinate:
6.28319,5.40856"
I imagine that there is a problem in the geometry (that I have imported with the CAD import modul), but I can't understand how I can find these coordinates in my draw in order to try to fix the error...
Thanks a lot for your attention and help!
Roberta
5 Replies Last Post 2011年5月9日 GMT-4 03:42
Posted: 1 decade ago 2011年5月8日 GMT-4 04:58
for "complex" or looping geometry it's worth to mesh manually, by parts, or even launch some seed points on critical edges / surfaces
Hi for "complex" or looping geometry it's worth to mesh manually, by parts, or even launch some seed points on critical edges / surfaces -- Good luck Ivar
Posted: 1 decade ago 2011年5月8日 GMT-4 07:54
I agree with mr Ivar. Most of the times with complicated geometries I do mesh manually, however I have always been having problems with seeding a circle or a cylindrical surface.
Comsol uses polynomials to approximate a circle thus if I define the coordinates of a point using the equation of the circumference, the point is always outside the circle. Is there any way to avoid such a drawback? I have trying to change the settings for the approximation but, alas, to no avail!
Cheers
Hi, I agree with mr Ivar. Most of the times with complicated geometries I do mesh manually, however I have always been having problems with seeding a circle or a cylindrical surface. Comsol uses polynomials to approximate a circle thus if I define the coordinates of a point using the equation of the circumference, the point is always outside the circle. Is there any way to avoid such a drawback? I have trying to change the settings for the approximation but, alas, to no avail! Cheers
Posted: 1 decade ago 2011年5月8日 GMT-4 14:20
I mostly seed a circle by selecting the edge and defining a distribution along this edge (you can even apply a function to the distribution to get uneven increasing or decreasing separations)
Hi I mostly seed a circle by selecting the edge and defining a distribution along this edge (you can even apply a function to the distribution to get uneven increasing or decreasing separations) -- Good luck Ivar
Posted: 1 decade ago 2011年5月9日 GMT-4 02:41
Thank you for your replays, they are very helpfull!
I'll try following your suggestions, but unfortunately I'm not so expert in the art of meshing... perhaps you can suggest me same teaching books or papers...
Thaks a lot again!
Roberta
Thank you for your replays, they are very helpfull! I'll try following your suggestions, but unfortunately I'm not so expert in the art of meshing... perhaps you can suggest me same teaching books or papers... Thaks a lot again! Roberta
Posted: 1 decade ago 2011年5月9日 GMT-4 03:42
No I do not have any books to propose, but I must say you learn meshing by doing, so follow and try examples passing on the forum, follow the videos, the exercises in the model Library ...
That is the best way, but start simple to get used to the different commands
Hi No I do not have any books to propose, but I must say you learn meshing by doing, so follow and try examples passing on the forum, follow the videos, the exercises in the model Library ... That is the best way, but start simple to get used to the different commands -- Good luck Ivar
