weld model
Posted 2011年6月8日 GMT-4 10:50 1 Reply
i have attached a 2D mph file where i am trying to simulate resistance spot welding phenomenon. In the file i have modeled two vertical conductors attached to the steel sheets where a weld joint has to be made on the exact spot, between the sheets, where the vertical rods are in contact to the sheets. I am trying to apply force from the top conductor side whereas the bottom one is fixed, so that the force + the applied current through the top conductors forces a weld joint between the sheets. However, i am facing problems doing so. Can somebody look at the file and get back to me with possible solution.
To understand the spot welding process please click on the youtube link below:
www.youtube.com/watch?v=AwL1CAg43PU
1 Reply Last Post 2011年6月9日 GMT-4 02:38
