how to find the x,y,z axis displacement
Anis Nurashikin Nordin
I have question regarding about on how to find the x,y,z axis displacement.
Currently I'm using Comsol 4.2 and attached are the file of my result. Is it correct because i'm quite confius about the result. Can everyone verify my result?
Regards
Anwar
4 Replies Last Post 2012年7月9日 GMT-4 12:58
Posted: 1 decade ago 2011年9月26日 GMT-4 01:53
because of the large displacement values for the eigenmode analysis ?
If so, reread the theory around eigenmode analysis:
You will then notice that amplitudes are not restrained, one can only get:
1) frequencies,
2) relative shapes
3) if you chose the correct normalisation, relative mode energy comparison.
But you never get any absolute displacement values.
I believe that the COMSOL developpers have left this feature (normalisation) this way as the default to REMIND all users about this effect. (at least for those noticing the large displacements and then ask themselves the question why )
Hi because of the large displacement values for the eigenmode analysis ? If so, reread the theory around eigenmode analysis: You will then notice that amplitudes are not restrained, one can only get: 1) frequencies, 2) relative shapes 3) if you chose the correct normalisation, relative mode energy comparison. But you never get any absolute displacement values. I believe that the COMSOL developpers have left this feature (normalisation) this way as the default to REMIND all users about this effect. (at least for those noticing the large displacements and then ask themselves the question why ) -- Good luck Ivar
Ananiah Durai Sundararajan
Posted: 1 decade ago 2012年5月3日 GMT-4 00:47
Hi Anis,
saw your model, I am trying to do displacement analysis for a pressure sensor, please tell me the procedure how u did it?
Hi Anis, saw your model, I am trying to do displacement analysis for a pressure sensor, please tell me the procedure how u did it?
Posted: 1 decade ago 2012年5月3日 GMT-4 01:38
Hi Anis,
Hi Ananiah Durai Sundararajan,
basically, can you explain more about your model.Kindly, to do the displacement analysis we must put the
model in air condition and some physical configuration such as fix constraint, linear elastic material.
Regards.
[QUOTE] Hi Anis, saw your model, I am trying to do displacement analysis for a pressure sensor, please tell me the procedure how u did it? [/QUOTE] Hi Ananiah Durai Sundararajan, basically, can you explain more about your model.Kindly, to do the displacement analysis we must put the model in air condition and some physical configuration such as fix constraint, linear elastic material. Regards.
Guillermo Andrés Borrero Becerra
Posted: 1 decade ago 2012年7月9日 GMT-4 12:58
I am modeling a SAW sensor for pressure measurement. And I also have to do a displacement analysis. Please can you send me your pressure sensor model?. I really appreciate your help.
Hi Ananiah Durai Sundararajan I am modeling a SAW sensor for pressure measurement. And I also have to do a displacement analysis. Please can you send me your pressure sensor model?. I really appreciate your help.
