radial magnetization for a PM
Hi everybody,
somebody knows how to set the radial magnetization for a PM in 3D environment
Jiang
4 Replies Last Post 2012年6月26日 GMT-4 22:38
Posted: 1 decade ago 2012年6月26日 GMT-4 01:48
have you tried to define a coordinate system ? i.e. a cylindrical one
Hi have you tried to define a coordinate system ? i.e. a cylindrical one -- Good luck Ivar
Posted: 1 decade ago 2012年6月26日 GMT-4 03:31
Hi Ivar
Thank you for your good idea.
I have another question, i want to calculate the Lorentz force generated by the motion of a conductor (a copper rod in my case) in a constant magnetic field. However, i can only calculate the Lorentz force contribution (mef.FLtz) which is the actually the force density induced in the conductor. How can i calculate the exact force induced by the eddy current ?
My model is in the 2D axisymmetric environment.
Jiang
Hi Ivar Thank you for your good idea. I have another question, i want to calculate the Lorentz force generated by the motion of a conductor (a copper rod in my case) in a constant magnetic field. However, i can only calculate the Lorentz force contribution (mef.FLtz) which is the actually the force density induced in the conductor. How can i calculate the exact force induced by the eddy current ? My model is in the 2D axisymmetric environment. Jiang
Posted: 1 decade ago 2012年6月26日 GMT-4 14:56
first if all in 2D-axi you can only have a Z motion, I believe, else I'm not sure how you get around the 2D-axi symmetry.
Then if you get a field density, which is the case for most variables, as these apply to each element dx*dy*dz (or dr*dphi*dz) it means you need to integrate over your domain or boundary, whatever applies, so that you get the total effect. (in 2D axi do not forget that sometimes you need the 2*pi*r "loop" multiplicant
Hi first if all in 2D-axi you can only have a Z motion, I believe, else I'm not sure how you get around the 2D-axi symmetry. Then if you get a field density, which is the case for most variables, as these apply to each element dx*dy*dz (or dr*dphi*dz) it means you need to integrate over your domain or boundary, whatever applies, so that you get the total effect. (in 2D axi do not forget that sometimes you need the 2*pi*r "loop" multiplicant -- Good luck Ivar
Posted: 1 decade ago 2012年6月26日 GMT-4 22:38
Hi Ivar
Thank you very much for your constructive advise.
Jiang
Hi Ivar Thank you very much for your constructive advise. Jiang
