Magnus Ringh
COMSOL Employee
2 years ago
2022年3月9日 GMT-5 05:34
It could be because the Cut Point dataset's dimensions don't match the Solution dataset's dimensions. For a 3D solution, for example, you need to use a Cut Point 3D dataset (unless you have some other dataset that has converted the 3D solution to a plane, for example; then you can use a Cut Point 3D dataset with the Cut Plane dataset as the input).
Magnus
Magnus
Jeff Hiller
COMSOL Employee
2 years ago
2022年3月9日 GMT-5 13:52
Hello Mya,
One possibility is that your model is 2D and you are trying to create a "Cut Point 3D" dataset, or vice versa.
Jeff Hiller
Hello Mya,
