Example does not work
Dear moderator,
I have a following problem: the microwave oven example does not work. I launch it through the File->Open model library menu, try to compute the "Solver Sequence 1" and get the error:
study feature time1 has no activation defined for physics rfw
The error entry in the "Problems" tree says following:
Out of memory during LU factorization.
Best wishes
Eugen
1 Reply Last Post 2010年11月22日 GMT+8 23:50
Posted: 1 decade ago 2010年11月22日 GMT+8 23:50
it could be a version issue, or just that you need more ram for this problem, check that the mesh is not too fine and try again (but making it coarser could also trigger an other typeof convrsion error
Hi it could be a version issue, or just that you need more ram for this problem, check that the mesh is not too fine and try again (but making it coarser could also trigger an other typeof convrsion error -- Good luck Ivar
