FSI, Motion of structure generates the fluid motion
Posted 2010年12月31日 GMT+8 19:20 Version 4.0a 0 Replies
Could you help me. I really need an example of FSI problem in which the motion of structure will generate the motion of fluid, such as the moving of a beam makes the fluid in the environment moving.
The examples of FSI in library are just about the motion of fluid by applying the inlet velocity. Then this motion will make the structure deform.
I modified the example of FSI in library to the case of structure movement to generate the fluid motion. But I failed.
Somebody could help me.
Thanks a lot
Happy new year.
If somebody has an example like that, cuold you send to me via email: btransi81@gmail.com
Hello tran si bui quang
