Problem of contacting crack edges
Hi everyone,
I am modeling a crack irradiated by laser source, which is represented by heat flux, and try to observe the closure of the crack due to the thermal expansion after the laser irradiation. I can have a very nice thermal expansion when the heat flux is applied in the beginning, but after crack edges touch, they keep moving, and finally "blend". In order to fix this problem, I was suggested to try to set both edges of the crack as "contact pair", however, Comsol reports error:
Error: 6170
Failed to evaluate variable.
- Variable: E
- Geometry: 1
- Boundary: 5
- Variable: pn_cp1_smpn
- Defined as: (E/h)
Failed to evaluate operator Jacobian
- Operator: if
- Geometry: 1
- Boundary: 5
Could someone help me with this problem?
Thanks!!
3 Replies Last Post 2012年2月17日 GMT-5 14:32
Posted: 1 decade ago 2012年2月17日 GMT-5 11:07
what is your variable E ? could it be the young modulus ? that is missing somewhere, or a naming conflict ?
Hi what is your variable E ? could it be the young modulus ? that is missing somewhere, or a naming conflict ? -- Good luck Ivar
Posted: 1 decade ago 2012年2月17日 GMT-5 11:20
Dear Ivar,
Sorry for making this mistake, this is the error code. The "E" was something I tried, but it didn't work.
Error: 6170
- Variable: auglagiter
- Geometry: 1
- Boundary: 5
- Defined as: ((E_smpn*min((0.001*(5^auglagiter)),1))/hmin_cp1_smpn)
- Operator: if
- Geometry: 1
- Boundary: 5
Hope you can answer!
All the best!
Chenyin
Dear Ivar, Sorry for making this mistake, this is the error code. The "E" was something I tried, but it didn't work. Error: 6170 Failed to evaluate variable. - Variable: auglagiter - Geometry: 1 - Boundary: 5 Failed to evaluate variable. - Variable: pn_cp1_smpn - Defined as: ((E_smpn*min((0.001*(5^auglagiter)),1))/hmin_cp1_smpn) Failed to evaluate operator Jacobian - Operator: if - Geometry: 1 - Boundary: 5 Hope you can answer! All the best! Chenyin
Posted: 1 decade ago 2012年2月17日 GMT-5 14:32
if I remeber right auglagiter is one if the COMOSL internal variables used in the contact definitions. You should check with the doc, as with 3.5 there was a good variable listing with explanations.
When you change too many things in COMSOL it looses sometimes track, then "my way" was to rebuild the model from scratch to be sure to have mainly default internal settings. As if I remember right most contact settings get set up correctly by default with COMSOL, although you can fiddle with them and sometimes help the sover to converge, butthen sometimes its difficult to set ack all the default settings.
Not sure its that helpfl, but there I cannot do much more, havent used 3.5 for a couple of years now ;)
Hi if I remeber right auglagiter is one if the COMOSL internal variables used in the contact definitions. You should check with the doc, as with 3.5 there was a good variable listing with explanations. When you change too many things in COMSOL it looses sometimes track, then "my way" was to rebuild the model from scratch to be sure to have mainly default internal settings. As if I remember right most contact settings get set up correctly by default with COMSOL, although you can fiddle with them and sometimes help the sover to converge, butthen sometimes its difficult to set ack all the default settings. Not sure its that helpfl, but there I cannot do much more, havent used 3.5 for a couple of years now ;) -- Good luck Ivar
