Where do you set the 'depth' of 2D model in 4.2a?
Before 4.x I used to set the 'depth' (z-axis) of a 2D model in subdomain setting. Where is it in 4.2a?
Thanks!
4 Replies Last Post 2012年4月17日 GMT-4 16:14
Posted: 1 decade ago 2012年4月13日 GMT-4 11:38
if the depth applies (not always the case), it's generally found in the main physics node
Hi if the depth applies (not always the case), it's generally found in the main physics node -- Good luck Ivar
Posted: 1 decade ago 2012年4月17日 GMT-4 12:24
Hello~
I'm new for the Comsol simulation, and have the similar question about the depth of 2D model.
May I ask what's the original value that Comsol set of the depth (at z-axis) for the 2D model? Also, where can I change the value in 3.5 version? Thank you so much!
Hello~ I'm new for the Comsol simulation, and have the similar question about the depth of 2D model. May I ask what's the original value that Comsol set of the depth (at z-axis) for the 2D model? Also, where can I change the value in 3.5 version? Thank you so much!
Posted: 1 decade ago 2012年4月17日 GMT-4 14:21
in most cases (but not always, pls check carefully ;) the default depth is 1[m] which means that everything in 2D is "per meter".
Unfortnately, it's too long since I last used 3.5, I just cannot remember, try to check the doc (I usually index my pdf, then search for "depth")
Hi in most cases (but not always, pls check carefully ;) the default depth is 1[m] which means that everything in 2D is "per meter". Unfortnately, it's too long since I last used 3.5, I just cannot remember, try to check the doc (I usually index my pdf, then search for "depth") -- Good luck Ivar
Posted: 1 decade ago 2012年4月17日 GMT-4 16:14
Hello~
In 3.5, it's in the subdomain physics setting.
[QUOTE] Hello~ I'm new for the Comsol simulation, and have the similar question about the depth of 2D model. May I ask what's the original value that Comsol set of the depth (at z-axis) for the 2D model? Also, where can I change the value in 3.5 version? Thank you so much! [/QUOTE] In 3.5, it's in the subdomain physics setting.
