                                2012年11月5日 GMT+8 21:02
conductivity is a material property that must be provided in the model. If you want to see a current distribution you would probably choose electric currents in AC/DC.
If the dielectric has very low conductivity and you want to see electrical fields only you can choose electrostatics.
Cheers
Edgar
Cheers
Edgar
                                2012年11月6日 GMT+8 11:51
                                                    Thank you very much Sir,
I tried solving the problem using Electrostatics; but when i plotted the conductivity under material properties, it was zero or no output was obtained. Is there a particular equation to compute electrical conductivity in a material sir?
Thank you.
Thank you.
                                2012年11月6日 GMT+8 16:13
                                                    As Edgar wrote, you cannot compute conductivity that way. It is a material property that needs to be provided as a model input.
                                2012年11月6日 GMT+8 16:47
And it should be added that in Electrostatics the conductivity of the materials is not even considered because by definition no galvanic currents are included.
Make sure you understand what you expect from the model. Are you mixing currents and conductivity here?
Cheers
Edgar
Cheers
Edgar
                                2012年11月7日 GMT+8 09:56
                                                    Thank you Eric
                            Thank you Eric
                                2012年11月7日 GMT+8 09:57
                                                    Thank you sir
                            Thank you sir
