Solving differential equations (Diffusion and Reaction) using the Mathematics Physics
Mikael Noerregaard Nielsen
Hi all
I'm trying to learn a bit of mathematical modeling of chemical reactions whilst combining it with the Mathematics physics of COMSOL. I am however, in a bit of trouble and I hope you can help me out with a few problems.
Problem 1) - Example 8.4
I have the following second order differential equation with the boundary conditions:
d^2y/dx^2-phi^2*y=0
x=0, dy/dx=0
x=1, y=1
This yields the analytical solution: y=cosh(phi*x)/cosh(phi).
My numerical solution is implemented using the General Form (PDE) in 1-D and writing the following as the source term with remaining parameters equal to zero:
f = -d^2y/dx^2+phi^2*y
with zero flux at x=0 and Dirichlet (y=1) at x=1.
The solutions are (I feel) pretty off, as the equations are relatively simple.
Problem 2) - Example 8.5
Equations are the same however, I now change the Dirichlet boundary condition to a Robin bc.
The bc is giving as:
x=1, dy/dx=Bi*(1-y), where y is evaluated a x=1
This produces the analytical solution:
y=cosh(phi*x)/(cosh(phi)+(phi/Bi)*sinh(phi))
I have tried implementing the Robin bc through the flux/source bc in COMSOL where g and q both are equal to Bi.
My numerical solution is off and doesn't seem to change with changing the parameter Bi.
Any help would be greatly appreciated. Models are attached as example 8.4 for problem 1 and example 8.5 for problem 2.
Best regards
Mikael
3 Replies Last Post 2015年11月26日 GMT+8 23:27
Magnus Ringh COMSOL Employee
Posted: 10 years ago 2015年11月26日 GMT+8 16:03
In both cases, you should put the d^2y/dx^2 term into the Gamma coefficient in the General Form PDE settings as
yx (that is, dy/dx)
to make the problem better posed.
Also, in example 8.5, to match
-n.Gamma (-dy/x) = g - qy
to
dy/dx=Bi*(1-y)
you should enter -Bi into the g and q coefficients' text fields.
With those changes, the numerical solutions in COMSOL match the analytical solutions.
Magnus Ringh, COMSOL
Hi, In both cases, you should put the d^2y/dx^2 term into the Gamma coefficient in the General Form PDE settings as yx (that is, dy/dx) to make the problem better posed. Also, in example 8.5, to match -n.Gamma (-dy/x) = g - qy to dy/dx=Bi*(1-y) you should enter -Bi into the g and q coefficients' text fields. With those changes, the numerical solutions in COMSOL match the analytical solutions. Best regards, Magnus Ringh, COMSOL
Posted: 10 years ago 2015年11月26日 GMT+8 17:56
Dear Magnus
Thanks for the answer. I shall try you suggestions during the day and get back to this thread.
Best regards
Dear Magnus Thanks for the answer. I shall try you suggestions during the day and get back to this thread. Best regards
Posted: 10 years ago 2015年11月26日 GMT+8 23:27
Dear Magnus
Thanks for your help - it works perfectly now.
Best regards
Dear Magnus Thanks for your help - it works perfectly now. Best regards
