Modeling Negative Stiffness Structure in series with resin (large strains)
Posted 2016年3月2日 GMT-5 18:06 Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions, Structural Mechanics Version 4.4 3 Replies
I'm modeling a metal NSS with a block of resin on top of it in 2D. I've set two constraints: fixed constraint on the bottom of the structure and prescribed displacement on the top of the resin. In other words, I want to compress the ensemble enough for it to show the negative stiffness behavior of the structure.
When I run the model using high values of Young's Modulus of the resin (E>400 kPa), it works fine. Nevertheless, if I use values of E smaller than 400kPa, I'm only able to run the model with very small displacements, which prevents me from observing the negative stiffness behavior. With larger displacements I get the following error: Failed to find a solution for all parameters, even when using the minimum parameter step...
I believe that the problem relies on the fact that the resin is subject to too large strains, since the E_resin<<E_structure (the structure works perfectly fine by itself).
Is there a way to make it work for small values of E (with large strains)? Do I have to get the nonlinear structural materials module?
Thank you so much for your help.
PS: I tried to submit the file but I got an error related to the file size .
3 Replies Last Post 2016年3月9日 GMT-5 02:34
