2 decades ago
2010年10月27日 GMT+8 23:40
After you solve your model, you can simply look at the results of the variables at a specific point.
To do this:
1. Click on 'Postprocessing' from the above menu
2. Select 'Cross-section Plot Parameters'
3. Select the 'Point' Tab
4. In the 'Expression' section, write the name of the variable of which results you want to see
5. In the 'Coordinates' section, write the coordinates of the point that you are interested in
6. Click OK
You will get the results of the selected variable on that point. If it is a transient analysis, the x-axis will be 'time'
Özen
To do this:
6. Click OK
Özen
2 decades ago
2010年10月27日 GMT+8 23:55
I'm sorry, But I couldn't find the post processing tab :( is it the same in all versions?
Thanks again for your help.
2 decades ago
2010年10月28日 GMT+8 05:08
For version 4.0, See Model Tree - Results
For former version, See the Menu - PostProcessing
[QUOTE]
[/QUOTE]
2 decades ago
2010年10月28日 GMT+8 05:13
Thank you so much! Since I could not find that, I did this :
Results --> data sets --> derived values --> point evaluation
It seems to do what I wanted. Thank you so much again for your help :-)
