COMSOL - MatLab combination without LiveLink( for MatLab)
Panagiotis Dimakopoulos
I use a class kit license COMSOL version which doesn't include the livelink for MatLab.
However I want to run a loop in MatLab using some COMSOL outputs.
Specifically I want to write a MatLab code that makes some iterations. The MatLab code includes a set of data.
COMSOL reads these data as inputs and then returns some outputs.
I compare these outputs with the reference values,
and if the difference diverges from zero then I change the input values and I rerun the
COMSOL. I repeat this loop as long as the difference is much bigger than zero
I would like to find a way to obtain this without using LiveLink for MatLab, but I got stuck.
Is there any idea?
Thank you in advance.
PD
1 Reply Last Post 2016年3月19日 GMT+8 00:13
Posted: 10 years ago 2016年3月19日 GMT+8 00:13
Whatever you can do in MATALB you, can also do in the Application builder using methods. However, you need some basic knowledge of JAVA.
