Import boundary condition from matlab
Hello everybody,
I already have a program in Matlab which calculate the solar radiation for 24 hours per day and i have a model in comsol 3.5a where one boundary condition is the solar heat flux calculated in Matlab and it is time dependent.
1) I would like to know if I can use my previous program in Matlab like a boundary condition even if I didn´t use the fem language because I've been reading the matlab interface guide and i didn't understand all the statements used there.
My point is when my comsol model runs the matlab program gives him the quantity of solar radiation for one boundary changing with the time.
2) Do I need to change the language in Matlab like the fem language?
Thank you so much, i really apreciate any answer!!!
Ivette.
3 Replies Last Post 2011年3月30日 GMT+8 07:26
Posted: 2 decades ago 2010年10月31日 GMT+8 22:52
I beleive you need to adapt your matlab code if you want to "drive" Comsol. But what if you make a list table and import that into COMSOL, your data should be rather smooth I believe, so only a few points should do, COMSOL would then interpolate in-between. If ou output the data in a text file, you can import it into a piecevise COMSOL function, see the doc.
Hi I beleive you need to adapt your matlab code if you want to "drive" Comsol. But what if you make a list table and import that into COMSOL, your data should be rather smooth I believe, so only a few points should do, COMSOL would then interpolate in-between. If ou output the data in a text file, you can import it into a piecevise COMSOL function, see the doc. -- Good luck Ivar
Posted: 2 decades ago 2010年10月31日 GMT+8 23:15
Hello, Ivar
I've read what you wrote, that's what I was afraid... to change my Malab language but I'll try your advice.
Thank you so much,
Ivette.
Hello, Ivar I've read what you wrote, that's what I was afraid... to change my Malab language but I'll try your advice. Thank you so much, Ivette.
Posted: 1 decade ago 2011年3月30日 GMT+8 07:26
How exactly do you import the list table into comsol?
Greg McDaniel
jgm@bu.edu
How exactly do you import the list table into comsol? Thanks, Greg McDaniel jgm@bu.edu [QUOTE] Hi I beleive you need to adapt your matlab code if you want to "drive" Comsol. But what if you make a list table and import that into COMSOL, your data should be rather smooth I believe, so only a few points should do, COMSOL would then interpolate in-between. If ou output the data in a text file, you can import it into a piecevise COMSOL function, see the doc. -- Good luck Ivar [/QUOTE]
