Line Heat Source
Hi everyone,
How can I define a line source of constant power per unit length in Heat Transfer in Solid module?
Kindly Help
Regards
Erkan
1 Reply Last Post 2016年4月14日 GMT-4 13:37
Posted: 9 years ago 2016年4月14日 GMT-4 13:37
Just draw the line in your geometry and assign a "Line Heat Source" node to it with the desired power per unit length. Toy example model attached.
Beware that line sources cause singularities, so the temperature distribution will be mesh dependent, see www.comsol.com/blogs/how-identify-resolve-singularities-model-meshing/ .
Just draw the line in your geometry and assign a "Line Heat Source" node to it with the desired power per unit length. Toy example model attached. Beware that line sources cause singularities, so the temperature distribution will be mesh dependent, see https://www.comsol.com/blogs/how-identify-resolve-singularities-model-meshing/ . Best, Jeff
