how to get the iv graph? final year project about geometrical analysis of silicon solar cell using comsol
Someone please help me with my final year project about geometrical analysis of silicon solar cell using comsol. i couldnt get the iv graph... and i need to vary parameter, change the material and the shape of the contact.. please help me.. :'(.. really appreciate those who reply.. thanks.
3 Replies Last Post 2016年5月28日 GMT-4 11:18
Posted: 9 years ago 2016年5月8日 GMT-4 10:45
Hi there ,
You can do these following steps
1) Do a stationary study type , Define some parameters in the the definitions heading ( ex - mat for material or any other name you want )
2) use ec ( electric currents ) physics interface and under it use terminal as supply ( use either current or voltage as source) . Terminals allow us to calculate directly current or voltage at the output , which can then be used in 1 D plot
3) Use auxiliary sweep in which you will vary your defined parameter name " mat " and give a range to sweep limit
4) under results click 1 D plot group under which click global plots>> terminals>> choose current or voltage as ur output ( u have already applied one of the above as your input )
It will give you a plot .
5) take help from prerecorded webneirs available in the comsol website , it contains many tutorials .
Hope above steps help
Atanu
Hi there , You can do these following steps 1) Do a stationary study type , Define some parameters in the the definitions heading ( ex - mat for material or any other name you want ) 2) use ec ( electric currents ) physics interface and under it use terminal as supply ( use either current or voltage as source) . Terminals allow us to calculate directly current or voltage at the output , which can then be used in 1 D plot 3) Use auxiliary sweep in which you will vary your defined parameter name " mat " and give a range to sweep limit 4) under results click 1 D plot group under which click global plots>> terminals>> choose current or voltage as ur output ( u have already applied one of the above as your input ) It will give you a plot . 5) take help from prerecorded webneirs available in the comsol website , it contains many tutorials . Hope above steps help Good luck Atanu
Posted: 9 years ago 2016年5月8日 GMT-4 11:31
hey..
thanx for the useful steps.. i will look forward onto it..
if there any probs, can i message u personally..
thanks shibu ghosh
hey.. thanx for the useful steps.. i will look forward onto it.. if there any probs, can i message u personally.. thanks shibu ghosh
Posted: 9 years ago 2016年5月28日 GMT-4 11:18
I am also a beginner just like you and trying to learn COMSOL from tutorials available on net . yes u can feel free to mail me , my mail ID ag4506@gmail.com
