basic help with parametric modeling
Posted 2010年11月17日 GMT+8 01:13 5 Replies
I hope someone can give me a clue.
I have a large model (quarter geometry yields 2.3 million DOF, running on 12Gb 8 core system) that is having trouble converging (at four days and counting). It is a magnetostatics/electrostatics AC/DC module model with high external currents in the superconducting range for my set of coils surrounded by the non-linear 1010 steel yoke material. It is the non-linear bit that creates the problem.
It has been suggested to use solutions from smaller current densities in combination with parametric solver. Current density sources two orders of magnitude lower than my final value solve in about 1/2 hour.
1) It appears this can be done with a continuation parameter in the Stationary solver settings. As described in one of the forum topics, I have multiplied my source terms (external current densities) by a parameter, in this case "Jm". I then presumably ramp this value to unity in some number of steps.
How do I define this parameter in the Stationary study settings dialogue?? If I choose "add" there are no variables to select from the dialogue box that appears and there and no option to type one in. I have tried defining this "Jm" as a Parameter under Global definitions, but I still have no selection choices when I click "add" under the Stationary Study Settings.
I believe I am mission something simple and basic to define this continuation parameter.
I am also using "Initial Values" set to "solution" method from "solver 1" (lower current density solution) in my "Study 2" under "Dependent Variables 1" node. I have left scaling as "automatic", "Variables not solved for" as "initial expression" method and "zero" solution.
2) It would also seem I could approach this with a parametric sweep added to the study, but I don't have any instructions for implementing this option.
Any clues?
Any clues?
5 Replies Last Post 2010年11月21日 GMT+8 04:31
