Re-mesh an imported mesh file
I have imported a .mphtxt file (containing a 3D geometry) into COMSOL 3.5 and tried to re-mesh all the sub-domains.
However, COMSOL gives me an error - "Error: 4121. Cannot remesh imported mesh".
Is there anyway I could do this operation?
Thanks.
4 Replies Last Post 2010年11月23日 GMT-5 00:16
Posted: 1 decade ago 2010年11月18日 GMT-5 05:25
traditional FEM tools work a lot on mesh as the geoemtrical base, COMSOL does not, you should ideall try to import geometries, or try to have 3.5a to generate a geoemtry from your mesh and then export/import the geoemtry, then remesh in V4
Hi traditional FEM tools work a lot on mesh as the geoemtrical base, COMSOL does not, you should ideall try to import geometries, or try to have 3.5a to generate a geoemtry from your mesh and then export/import the geoemtry, then remesh in V4 -- Good luck Ivar
Posted: 1 decade ago 2010年11月22日 GMT-5 09:23
Thank you for the reply.
Can you please suggest as to how I can create geometry from the mesh file in 3.5a?
Hello, Thank you for the reply. Can you please suggest as to how I can create geometry from the mesh file in 3.5a?
Posted: 1 decade ago 2010年11月22日 GMT-5 15:08
take a read in the doc, i.e. chapter on "Creating a Geometry from a Mesh" p369 in guide.pdf for 3.5a.
It really worth to "index" your pdf files and run a search on them, most answers are therein
Hi take a read in the doc, i.e. chapter on "Creating a Geometry from a Mesh" p369 in guide.pdf for 3.5a. It really worth to "index" your pdf files and run a search on them, most answers are therein -- Good luck Ivar
Posted: 1 decade ago 2010年11月23日 GMT-5 00:16
Thank you very much.
