Again, mass conservation with MS equations
Posted 2010年11月25日 GMT+8 20:58 2 Replies
This question has to do with another topic I started last week but with which, unfortunately, nobody could help me.
In the file I have attached, I created a pipe through which oxygen and water (gas phase) circulate. Navier-Stokes and Maxwell-Stefan equations are used to describe momentum and mass transport. The lower boundary (boundary 3) is supposed to be a reactive surface and therefore an oxygen flux is set as boundary condition. If I calculate the oxygen mass flow (kg/s) that is going into the system (using the boundary integration tool, integrating the flux) and subtract the oxygen mass flow that is going out, I approximately obtain the same amount of oxygen that is disappearing through the reactive boundary, which means that mass balance for oxygen meets satisfactorily. However, if I do the same to check the water mass balance, the result is really not good. Calculating the difference between the water mass flux at the inlet and at the outlet, I obtain a noticeably different amount than the water that is being generated on the reactive boundary, which is the same (in mass terms) as the oxygen that is being consumed. The minumum mesh element quality is 1.000, so I guess that I cannot blame this on truncation errors or similar.
Can anybody give me an explanation for this?
Thank you very much for your help!
2 Replies Last Post 2010年11月30日 GMT+8 18:02
