Initial Values for Laminar Flow
I'm having issues with setting inital values. I have a box with a helium inflow on top, and outflow at bottom. Inside there's a small cell. It all works fine, when I set-up these values to proper domains/boundaries:
LF/Fluid prop.
Pressure 1[atm]
LF/Initial Values
Velocity field (0,0,0)
Pressure 1[atm]
LF/Inlet (Laminar Inflow)
Av. Velocity - 1m/s
Lentr - 1m
LF/Outlet
Pressure, no visc. stress - 1[atm],
I plot 3D Arrow volume showing velocity field with flow deformations around the cell. Here's the thing. The target velocity is 30m/s. After I change it to this value, the simulation crashes with information, that consistent inital values cannot be found. I've been changing pressures, entrance length, inital velocity field etc, but I cant find any boundary conditions, that would let me see the results.
Thank You in advance for any tips and hints.
Cheers
2 Replies Last Post 2010年11月26日 GMT-5 09:02
Posted: 1 decade ago 2010年11月26日 GMT-5 08:42
I wounder if it could comes from the numerous pressure definitions you have, pls check carefully as you have relative, gauge and absolute pressures. Test on a simple example that you can calculate analytically.
I would try to define "p" on the initial values and on one inlet or exclusively the outled, only
Hi I wounder if it could comes from the numerous pressure definitions you have, pls check carefully as you have relative, gauge and absolute pressures. Test on a simple example that you can calculate analytically. I would try to define "p" on the initial values and on one inlet or exclusively the outled, only -- Good luck Ivar
Posted: 1 decade ago 2010年11月26日 GMT-5 09:02
I set up INITIAL PRESSURE to 1E6 Pa, FLUID PROPERTIES/ABS PRESSURE to 110 Pa and OUTLET PRESSURE to 1000 Pa to distinguish which has a greater impact on results. Simulation runs w/o a problem. Thing is, that a 3D Surface with Pressure plot sets value of 1006 Pa at Inlet, and 1000 Pa at Outlet, so it turns out, that Pressure is governed by an outlet pressure? Seems a bit weird to me.
Any ideas?
I set up INITIAL PRESSURE to 1E6 Pa, FLUID PROPERTIES/ABS PRESSURE to 110 Pa and OUTLET PRESSURE to 1000 Pa to distinguish which has a greater impact on results. Simulation runs w/o a problem. Thing is, that a 3D Surface with Pressure plot sets value of 1006 Pa at Inlet, and 1000 Pa at Outlet, so it turns out, that Pressure is governed by an outlet pressure? Seems a bit weird to me. Any ideas?
