Simulating a microcantilever (Problems connecting multiple physics)
Posted 2010年11月28日 GMT-5 07:11 1 Reply
I'd like to simulate a microcantilever deflecting under electrostatic actuation. The cantilever is of non-uniform width. Only a portion of the area below the cantilever is to act as the electrode. I'd like to calculate the pull-in voltage of the structure. Could you please offer me some directions on how to proceed?
I know that I should use the moving mesh, electrostatics and solid mechanics physics. However,I'm not clear as to what exactly I should do with the modules. Also, how should I model the air around the cantilever? Air has nearly the same permittivity as vacuum, and I'm not modelling squeeze film damping, so do I need to model the air as well?
I added the following:
Solid Mechanics:
Fixed Constraints
Boundary Load (how do I connect the Fes force to this boundary load? What values should I give in the user defined Fx,y,z?)
Prescribed Displacement
Electrostatics:
Electric Potential (value V_in NaN as parameter)
Ground
Force Calculation ( with a force Fes)
Moving Mesh:
Prescribed Deformation (u,v,w)
As of now the system on simulation(varying V_in) is giving no displacement.
I'm not sure how to proceed and any help is welcome.
Solid Mechanics:
Fixed Constraints
Electrostatics:
Ground
Moving Mesh:
1 Reply Last Post 2010年11月28日 GMT-5 10:16
