average above parameterized surface
I have a problem with that, it just does not work. I had just NaN in exported data. No matter what parameters i need to be averaged. But contours work just fine on this surface.
2 Replies Last Post 2010年12月1日 GMT-5 04:09
Posted: 1 decade ago 2010年12月1日 GMT-5 02:54
I cannot really udnerstand what you mean, the average work ON a surface/boundary, and for a cut plane/surface inside a domain, if you tweak the solution accordingly (havent really tried that one).
what do you mean with "above", and in wich version + applciation mode/physics ?
Hi I cannot really udnerstand what you mean, the average work ON a surface/boundary, and for a cut plane/surface inside a domain, if you tweak the solution accordingly (havent really tried that one). what do you mean with "above", and in wich version + applciation mode/physics ? -- Good luck Ivar
Posted: 1 decade ago 2010年12月1日 GMT-5 04:09
Ok, i see, i need some parameters to be averaged on parameterized surface i created. Cant i do this? Data fields is ok, solution is ok too, problem is in postprocessing. I can calculate average on boundary but on parameterized surface i got NaN. Version 4.0a, structural analysis.
