Failed to find a solution on popped up while simulated a 2 spiral coils
Posted 2016年6月27日 GMT+8 17:20 Low-Frequency Electromagnetics Version 4.4 2 Replies
Hello everyone
I am trying to model a 2-spiral coil system consisting of transmitter coil and receiver coil.
I use the magnetic field and electrical circuit physics and time dependent study in order to get the induction voltage and magnetic flux density value.
I set the coils as single turn coil with circuit current as the coil excitation. I chose a sine source with voltage source of 2 V and frequency of 500 kHz.
But, I got an error like this:
Failed to find a solution.
Singular Matrix
For mesh-case 0 There are 1958 degrees of freedom that do not occur in any equation (empty columns in matrix) for the variable comp1.mf.Vcoil.
at coordinates: (-0.00556995,-0.00127249,-0.000349562), .........
-Feature: Time-Dependent Solver 1 (sol2/t1)
Would you like to give me some advise on how to simulate this correctly?
I really appreciate any help you can provide.
Thank you very much
Singular Matrix
Thank you very much
2 Replies Last Post 2016年6月28日 GMT+8 21:05
