                                2010年12月4日 GMT+8 20:45
from what I remembered, only one (without passing through matlab) but you could have several parameter for the sae sweep, check the doc
of the type
param1 param2 ...
1 1.1 2 2.2 3 3.3
giving
param1  = {1 2 3}
param2 = {1. 2.2 3.3}
of the type
param1 param2 ...
1 1.1 2 2.2 3 3.3
giving
param1  = {1 2 3}
                                2010年12月4日 GMT+8 22:56
I knew this method ;but by using this method only value the first parameter changes the second is fake
                                2010年12月4日 GMT+8 23:24
                                                    Mohammadreza,
I used this method and it works properly. You might want to check it in a simple place like expressions and plot it Vs a parameter.
Again, if your parameters are vectors say {a} and {b}
So in GUI, they are
a1 b1 a2 b2 a3 b3...etc
Good luck,
Stephan
                            Mohammadreza,
So in GUI, they are
Good luck,
Stephan
                                2010年12月5日 GMT+8 16:20
there is one limitation: the first parameter must always be monotonously increasing (or decrasing)
