FLAME
Hello!
SOmeone have some documents, model or knows how to simulate a flame in Comsol?
It is possible for example to simulate a methane burner?
7 Replies Last Post 2015年4月23日 GMT-4 03:48
Posted: 1 decade ago 2010年12月7日 GMT-5 10:47
I suppose it depends on thich physical properties you are after, in some sens it could be called a plasma, no ?
Hi I suppose it depends on thich physical properties you are after, in some sens it could be called a plasma, no ? -- Good luck Ivar
Posted: 1 decade ago 2010年12月7日 GMT-5 11:14
No noting related plasma.
I mean I have all the reaction and the species in Chemkin format, I have the geometry of the burner, but I am not able to couple the chemical reaction module with the CFD flow to plot the flame profile and the fluid flow near the flame!
No noting related plasma. I mean I have all the reaction and the species in Chemkin format, I have the geometry of the burner, but I am not able to couple the chemical reaction module with the CFD flow to plot the flame profile and the fluid flow near the flame!
Posted: 1 decade ago 2010年12月7日 GMT-5 15:05
OK I see, I'm more a physicist than a chemist ;)
unfortunately I'm not used to these equation couplings, as I use the "chemistry" physics mainly for its (former) fluidics applications, so I cannot help much here
Hi OK I see, I'm more a physicist than a chemist ;) unfortunately I'm not used to these equation couplings, as I use the "chemistry" physics mainly for its (former) fluidics applications, so I cannot help much here -- Good luck Ivar
Posted: 1 decade ago 2011年2月15日 GMT-5 07:53
Hi !
Just wondered if you have found any solution to this ?
I have more or less the same problem, having all the kinetics and all the heat transfer equations, but cant find any way to connect them properly so that my chemical reactions follow my combustion/heat transfer results.
In my model there is no movement, it's a pure heat transfer in gas that causes chemical reactions within the gas to occur.
NE
[QUOTE] No noting related plasma. I mean I have all the reaction and the species in Chemkin format, I have the geometry of the burner, but I am not able to couple the chemical reaction module with the CFD flow to plot the flame profile and the fluid flow near the flame! [/QUOTE] Hi ! Just wondered if you have found any solution to this ? I have more or less the same problem, having all the kinetics and all the heat transfer equations, but cant find any way to connect them properly so that my chemical reactions follow my combustion/heat transfer results. In my model there is no movement, it's a pure heat transfer in gas that causes chemical reactions within the gas to occur. NE
Posted: 1 decade ago 2015年4月22日 GMT-4 05:37
Please has any one been able to simulate flame propagation in tube? I have done this experimentally but trying to see if it is possible to simulate the process in COMSOL. Any help is appreciated
Hello, Please has any one been able to simulate flame propagation in tube? I have done this experimentally but trying to see if it is possible to simulate the process in COMSOL. Any help is appreciated
Posted: 1 decade ago 2015年4月22日 GMT-4 10:19
Like this?
www.comsol.com/story/multiphysics-analysis-of-a-burning-candle-14455
Like this? http://www.comsol.com/story/multiphysics-analysis-of-a-burning-candle-14455
Posted: 1 decade ago 2015年4月23日 GMT-4 03:48
Thanks Daniel for the link, though it require me going for the training which for now I cannot afford to do the travel since am in the UK. Please if there is any other useful information, do kindly help me with.
