Some problems of Bandgap Analysis of Photonic Crystal (ver 3.5)
Hello All,
I am trying to run the built-in model of Bandgap Analysis in ver 3.5. But I got some problem:
Error: 6170
Failed to evaluate variable.
- Variable: lambda
- Global scope
- Expression: imag(lambda)
- Expression: -imag(lambda)/(2*pi)
Am I supposed to give some initial value of lambda somewhere?
By the way, way the ver4.0 does not provide this model? Does it still support this calculation for 4.0?
Thank you!!
Xing
7 Replies Last Post 2013年4月24日 GMT-4 03:37
Posted: 1 decade ago 2010年12月13日 GMT-5 16:30
normally "lambda" is defined by COMSOL when you do an eigvenvalue or eigenfrequency solveing, except if you have redefined it yourself, in which case there might be a variable naming conflict
I believe the bandgp example appears again in 4.1
Hi normally "lambda" is defined by COMSOL when you do an eigvenvalue or eigenfrequency solveing, except if you have redefined it yourself, in which case there might be a variable naming conflict I believe the bandgp example appears again in 4.1 -- Good luck Ivar
Posted: 1 decade ago 2010年12月13日 GMT-5 17:24
Dear Ivar,
Many thanks for your rapid reply!!
I agree that lambda itself is an unknown and should be determined in eigenvalue or eigenfrequency solvers. However, when I run the example, comsol immediately tells me the failure of lambda evaluation. I think there might be some problems there, because I just simply open it and run without revising anything.
Can you tell me how should i do regarding this example model or kindly check if there is any problem in this model?
I also install 4.0a and 4.1, but i did not obtain a similar example model in these two versions. Do you have any updated one?
I very appreciate your help!!!!!!!!
Xing
Dear Ivar, Many thanks for your rapid reply!! I agree that lambda itself is an unknown and should be determined in eigenvalue or eigenfrequency solvers. However, when I run the example, comsol immediately tells me the failure of lambda evaluation. I think there might be some problems there, because I just simply open it and run without revising anything. Can you tell me how should i do regarding this example model or kindly check if there is any problem in this model? I also install 4.0a and 4.1, but i did not obtain a similar example model in these two versions. Do you have any updated one? I very appreciate your help!!!!!!!! Best, Xing
Posted: 1 decade ago 2010年12月14日 GMT-5 02:54
no I have nothing more than the latest patch for 4.1 from the Comsol site, I know they are working hard to update and verify all models and that with the major v4 changes in the soft they need still some months to get all models back ;)
Hi no I have nothing more than the latest patch for 4.1 from the Comsol site, I know they are working hard to update and verify all models and that with the major v4 changes in the soft they need still some months to get all models back ;) -- Good luck Ivar
Posted: 1 decade ago 2010年12月14日 GMT-5 10:36
Dear Ivar,
I very appreciate your reply, especially your response regarding the examples in the new versions!!
But, can you provide me more advise for the error code:
Error: 6170
- Variable: lambda
- Global scope
It seems that comsol encounters some problem with evaluating lambda. How can I do to fix this problem??
Thank you!!
Xing
Dear Ivar, I very appreciate your reply, especially your response regarding the examples in the new versions!! But, can you provide me more advise for the error code: Error: 6170 Failed to evaluate variable. - Variable: lambda - Global scope Failed to evaluate expression. - Expression: imag(lambda) Failed to evaluate expression. - Expression: -imag(lambda)/(2*pi) It seems that comsol encounters some problem with evaluating lambda. How can I do to fix this problem?? Thank you!! Best, Xing
Posted: 1 decade ago 2010年12月14日 GMT-5 11:04
The model works perfectly fine, just that you need to follow it through the complete sequence mentioned in tutorial.
It won't work, however, if you just open it from model library and click compute button. The reason being that it needs initial field distribution and frequency value out of eigen frequency analysis to proceed with parametric solver. Once the result of parametric solver is computed, initial values of eigen frequency analysis are no longer available. Hence you get that error message.
Hope this helps.
The model works perfectly fine, just that you need to follow it through the complete sequence mentioned in tutorial. It won't work, however, if you just open it from model library and click compute button. The reason being that it needs initial field distribution and frequency value out of eigen frequency analysis to proceed with parametric solver. Once the result of parametric solver is computed, initial values of eigen frequency analysis are no longer available. Hence you get that error message. Hope this helps.
Posted: 1 decade ago 2010年12月14日 GMT-5 15:31
Dear All,
Thank you very much for all of your help!!
I eventually figure it out!! Shakeeb is right, once you obtained the results, you cannot run it. So, in the example model, we cannot execute directly, since the results have been there. But, if you click "Re-do," everything goes well!!
Thank you!!
Xing
Dear All, Thank you very much for all of your help!! I eventually figure it out!! Shakeeb is right, once you obtained the results, you cannot run it. So, in the example model, we cannot execute directly, since the results have been there. But, if you click "Re-do," everything goes well!! Thank you!! Best, Xing
Radwanul Hasan Siddique
Posted: 1 decade ago 2013年4月24日 GMT-4 03:37
Hello guys,
I want to calculate the photonic bandgap of 1D or 2D PhC. Does anyone has any model or example for this kind of problem?
I really do appreciate your help.
Thank you in advance.
Hello guys, I want to calculate the photonic bandgap of 1D or 2D PhC. Does anyone has any model or example for this kind of problem? I really do appreciate your help. Thank you in advance.
