9 years ago
2016年8月26日 GMT-4 10:49
Did you apply PEC or impedance boundary condition on cavity wall? Perform surface integration of power density at cavity wall to determine power absorption by wall.
9 years ago
2016年8月26日 GMT-4 11:54
Dear Sohan, Thanks for your attention, first I have assigned the cavity walls PEC then I have changed them into Impedance boundaries, because I also added the heat transfer in solids and convective heat flux for the outer surface of the cavity. More or less I followed the example of RF Heating.
9 years ago
2016年8月29日 GMT-4 11:40
Integrate the power absorbed in wall and load. Then determine the absolute value of S11 parameters any point on surface of the domain. Inpt_power*(1-abs(S11)^2) should be equal to integrated power. If this numbers are different than check for mesh quality. Let the software select the meshing scheme.
9 years ago
2016年8月29日 GMT-4 13:58
I suppose that I have to do these integrations at one fixed frequency, right?
