Geometry Problem
If I draw a circle and then use array function to copy it multiple times (The reason for doing this is to place these circles at a particular distance). Then if I want to change the radius of some circles which were copied via array function. How can I peform adjustment in radius of these circles?
Need your help
4 Replies Last Post 2010年12月23日 GMT-5 03:01
Posted: 1 decade ago 2010年12月22日 GMT-5 08:12
I seem to remember thsi is not possible in 3.5a, but it should be in 4.1 via a variable but I would have to check, as COMSOL might have forgotten this option like that, if so send them a suggestion for next release, as it's rather usefull I agreee
Hi I seem to remember thsi is not possible in 3.5a, but it should be in 4.1 via a variable but I would have to check, as COMSOL might have forgotten this option like that, if so send them a suggestion for next release, as it's rather usefull I agreee -- Good luck Ivar
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 2010年12月22日 GMT-5 09:59
This works in version 4 if you define the radius of the circle as a parameter r0, for example (in the Global Definitions>Parameters node's Settings window). You can then change the radius of all circles created with the array feature by changing the value of r0 and rebuilding the geometry.
Magnus Ringh, COMSOL
This works in version 4 if you define the radius of the circle as a parameter r0, for example (in the Global Definitions>Parameters node's Settings window). You can then change the radius of all circles created with the array feature by changing the value of r0 and rebuilding the geometry. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 2010年12月22日 GMT-5 20:50
Ya I can do this as to change the radius of all the circles via global definitions command. But I dont want to change the diameter of all the circles however, I want to change the radius of few. For example I make a circle with radius 1.5 mm, then I pasted 100 times in a array . Now I want to change the radius of only few among the 100 circles say 20 out of 100 circles. Can I do this in COMSOL 4???
Posted: 1 decade ago 2010年12月23日 GMT-5 03:01
As in v4 these formulas for generating arrays are linked you need to redefine the equations for just some of them, even in SolidWorks CAD you need to rewrite new equations if you want to address just some of a general array. So that is not trivial
Hi As in v4 these formulas for generating arrays are linked you need to redefine the equations for just some of them, even in SolidWorks CAD you need to rewrite new equations if you want to address just some of a general array. So that is not trivial -- Good luck Ivar
