got an error in the bigger size copper deposition
Posted 2010年12月23日 GMT+8 15:58 Chemical Reaction Engineering, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 3.5a 1 Reply
I'm trying to use and modify the copper deposition model then I get an error when solve as below.
the model works well in the micron size but the error was found when I make it's wider between anode and cathode about 5 centimeter but the cavity is still 40 micrometer
In the error log, dependent variables, lm1 and lm2 what do they do in equation of Moving mesh(ALE)?
Error 7248
Exception:
com.femlab.jni.FlNativeException: Undefined value found Solvermodel
Stack trace:
at solvermodel.cpp, row 1837, (Undefined value found in the stiffness matrix.
There are 21 equations giving NaN/Inf in the matrix rows for the variable V
at coordinates: (-0.005,0.05), (-0.0045,0.05), (-0.004,0.05), (-0.0035,0.05), (0.005,0.05), ...
There are 21 equations giving NaN/Inf in the matrix rows for the variable lm1
There are 21 equations giving NaN/Inf in the matrix rows for the variable lm2
and similarly for the degrees of freedom, NaN/Inf in the matrix columns)
at com.femlab.solver.FlSolver.femTime(Native Method)
at com.femlab.solver.FemTime.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
and I dont understand the constant phi_s_anode and phi_s_cathode, from butler-volmer equation, are they standard electrode potential or supply voltage? and how would I change the electrode such as use Platinum for anode an Copper for cathode? because in the example model does not clear what the electrode is.
Thank you very much for your help
Pardon for my bad english
Error 7248
Exception:
Stack trace:
1 Reply Last Post 2010年12月23日 GMT+8 16:24
