PDE and any physics together
I am trying to add a source in the Heat Transfer (HT) module by applying a formulation which is a function of temperature. I add a PDE coefficient form. Then I enter "T" for the temperature expecting to take the temperature from HT module. The source term is a rate and it is in derivative form (only time derivative). Since it has only time derivative, an initial cond. is enough I thing. When I solve the program, I see the results is not convenient with exact solution that I made by hand. For example, When I plot the figures of each variable (T and source term) I see they are different. I should also note that HT module asks unit for source in W/m^3 but I have no any unit in PDE form. I neglect the red colour unit error. Thanks...
9 Replies Last Post 2011年1月4日 GMT-5 05:42
Posted: 1 decade ago 2011年1月3日 GMT-5 06:21
I calculate the formulation in PDE form by taking the variables from plots for certain node and certain time and formulation does not give a equivelance.
Posted: 1 decade ago 2011年1月3日 GMT-5 06:25
The unit is important or not? If important, How can I enter a unit for a variable in PDE form?
Posted: 1 decade ago 2011年1月3日 GMT-5 07:22
Units are important for us users to check that we are putting up correctly the physics, by the way "unitless" or unit [1] is just as imporant, it's just a particular case. But COMSOL only Warns you about unit errors, so it will calculate with the values you give, assuming they are consistent in any case, so it's you the programmer/end use's responsability to know what you/we are doing ;)
It iscorrect that even in v4.1 units int he global expressions or user defined PDE's are not fully implemented so there you must be carefull to add up consistent elments. I mostly multiply my variables by
MyPDE_variable*1[my_desired_units]
in the equation to help stay consistent
Hi Units are important for us users to check that we are putting up correctly the physics, by the way "unitless" or unit [1] is just as imporant, it's just a particular case. But COMSOL only Warns you about unit errors, so it will calculate with the values you give, assuming they are consistent in any case, so it's you the programmer/end use's responsability to know what you/we are doing ;) It iscorrect that even in v4.1 units int he global expressions or user defined PDE's are not fully implemented so there you must be carefull to add up consistent elments. I mostly multiply my variables by MyPDE_variable*1[my_desired_units] in the equation to help stay consistent -- Good luck Ivar
Posted: 1 decade ago 2011年1月3日 GMT-5 08:41
MyPDE_variable*1[my_desired_units] did not work.
Also I recognized that all boundary conditions should Neuman type, not Drichlet, although any BC is not required for a time derivative only. Even that case results are sometimes so different from exact values, I could not understand why?
MyPDE_variable*1[my_desired_units] did not work. Also I recognized that all boundary conditions should Neuman type, not Drichlet, although any BC is not required for a time derivative only. Even that case results are sometimes so different from exact values, I could not understand why?
Posted: 1 decade ago 2011年1月3日 GMT-5 08:49
I named the variable R for PDE and I wrote R*1[W/m^3] in source term but it does not work. I also tried it in global expressions but it also did not work. The other desadvantage of writing the expression in global expressions, I cannot plot it at global variables plot --> predefined quantities in postprocessing, It writes ... is not a valid global expression.
Posted: 1 decade ago 2011年1月3日 GMT-5 09:32
I should have been claeare ;)
you cannot define the variable with the units in COMSOL (in the name field),
but I use the variables in the equations by multiplying them by *1[my_units]
Sorry for that (note this will certainly change in v4.2 or 4.3)
Hi I should have been claeare ;) you cannot define the variable with the units in COMSOL (in the name field), but I use the variables in the equations by multiplying them by *1[my_units] Sorry for that (note this will certainly change in v4.2 or 4.3) -- Good luck Ivar
Posted: 1 decade ago 2011年1月3日 GMT-5 14:46
Dear Ivar
What about the errors in calculating a simple example such as u=T^2 where u is the variable for PDE and T is temperature from HT module. In this example, the results are not same with the exact soln. mostly. I chose the Nueman condition for each boundary.
Dear Ivar What about the errors in calculating a simple example such as u=T^2 where u is the variable for PDE and T is temperature from HT module. In this example, the results are not same with the exact soln. mostly. I chose the Nueman condition for each boundary.
Posted: 1 decade ago 2011年1月3日 GMT-5 17:20
I do not understand why the boundary conditions should be Nueman type for this manner (for only time derivative eqn. in order to put the source or reaction rate into the HT or Mass physics) . If I use spatial derivatives in PDE form, I should enter a boundary condition for that derivatives, rigth?
Posted: 1 decade ago 2011年1月4日 GMT-5 05:42
what about uploading your "simple model" it's easier for us out here to talk about it then, or explain step by step the way you build it. Such exercices also often helps to find the solution ;)
Hi what about uploading your "simple model" it's easier for us out here to talk about it then, or explain step by step the way you build it. Such exercices also often helps to find the solution ;) -- Good luck Ivar
