boundary conditions, pressure losses due to friction
Hi! i need help one more time =(
my question is - i have flow of fluid in the pipe, i know mass flow rate, and i know inlet pressure.
How can i calculate pressure losses due to friction?
Thanks =)
1 Reply Last Post 2011年1月15日 GMT+8 04:14
Posted: 1 decade ago 2011年1月15日 GMT+8 04:14
if I remember right (CFD is not my main occupation) head losses in a pipe system comes from known pipe parameters: length, section ..., liquide properties: density, viscuosity ... environmental values: temperature, pressure ..., but also surface roughness of the piping, all for laminar flow, and with turbulences everything is even more fun ;)
Formulas relating these are Poiseille, for pressure drop of the flow, mass & momentum conservation in general ...
So if you can express all this in a reasonnable way , including enough BC, as you are suggesting, except for one unknown (i.e pipe surface roughness), then you can get Comsol to find by least square (via a global equation) the best fit for this unknown (sure I suppose there is only 1 unique solution)
It's not a precooked answer, but at least it's the methodology I would use ;)
PS: in engineering fluidics, I find there are very many "engineering" formulas, obtained in empiric ways, I have learned to be rather suspicious about them and always analyse carefully the units in there, as many of the "constants" are very physics dependet, based on often forgotten assumptions.
Hi if I remember right (CFD is not my main occupation) head losses in a pipe system comes from known pipe parameters: length, section ..., liquide properties: density, viscuosity ... environmental values: temperature, pressure ..., but also surface roughness of the piping, all for laminar flow, and with turbulences everything is even more fun ;) Formulas relating these are Poiseille, for pressure drop of the flow, mass & momentum conservation in general ... So if you can express all this in a reasonnable way , including enough BC, as you are suggesting, except for one unknown (i.e pipe surface roughness), then you can get Comsol to find by least square (via a global equation) the best fit for this unknown (sure I suppose there is only 1 unique solution) It's not a precooked answer, but at least it's the methodology I would use ;) PS: in engineering fluidics, I find there are very many "engineering" formulas, obtained in empiric ways, I have learned to be rather suspicious about them and always analyse carefully the units in there, as many of the "constants" are very physics dependet, based on often forgotten assumptions. -- Good luck Ivar
