2011年1月18日 GMT-5 14:42
I believe you need to use matlab to treat your data, I'm not convinced (but I might be wrong) that its possible within the GUI environment. You can always save the data in the middle, but that means 2 file. In fact you can also make "n" files with the parametric sequencer in 3.5a
2011年1月19日 GMT-5 15:27
Thanks for the answer. That would be an useful option for latter versions of Comsol, I guess...
I searched another way to do the job, and found it: simply using the "store solution" option in the advanced solver settings ! Also, I discovered that I could split the timestep list into several intervals, which enables me to precisely tune the timestep along the run (timestep list = range[0,5,50] range[50,10,90] range[90,1,100], and use "strict" for the timesteps used by solver, in the time stepping tab).
I also found something useful: using the generalized-alpha method, one can manually define the solver timestep list (a composite range or even a function) AND a different output timestep list.
2011年1月19日 GMT-5 15:51
indeed there are many solver settings and choices. the use of several ranges() in series is nice, the default solver expect assymptotical convergene, so using strict or intermediate time-steppingis usefull for harmonic or pulsed signals. COSOL cannot understand all our desires (yet?)
2011年3月1日 GMT-5 16:33
HI
I am using Chemical engineering module 3.5 a. I want to used different time steps in my model. I try to used two steps as you described here but it gave me an error. Could you please tell me how did you split the timestep.
Chandima B Ekanayake
HI
2011年3月2日 GMT-5 02:04
for sets (use { } in v4, but NOT in v3.5 !) you must respect that the first series (if several parameters) is strictly monotonously increasing (or decreasing), no repeated values. then normally it works (also in 3.5)
In v4 you can learn how to assemble several "range(,,)" in the Parameter section as you will get written out the result. In v3.5 you might be able to define a function with one and then plot it
so
0 1 2 3 4 4 5 6
is no good 4 is repeated, just as
range(0,0.1,1) range(1,0.2,2)
because 1 is repeated once per range
range(0,0.1,1) range(1.2,0.2,2)
works better
in V4 you can write
10^{range(0,0.1,2)} = {10^0 10^0.1 10^0.2 ... 10^2}
But you have the "range" button to help you set up these series, also with different functions
if you have two parameters
param1 param2
then you need to divide your set in pairs
{1 2 1.5 3 2 4 2.5 5 3 5} gives param1 = {1 1.5 2 2.5 3} and param2 = {2 3 4 5 5}
If I remember right pls check param2 can repeat the same value BUT NOT param1
I remember that in v3.5 I sometimes used a dummy "param" just to identify my cases and the others where moving up and down. However, do not forget that the solver is using previous step as starting point so if you put values jumping too much up&down the solver might have problems, and if you do not turn off the intermediate steps, the solver might try to calculate for param1 = 1.25 in between two values, and sometimes this is nonsense for the other parameters
so
0 1 2 3 4 4 5 6
works better
in V4 you can write
param1 param2
