saving comsol model from matlab livelink
Posted 2011年1月19日 GMT+8 01:00 Interfacing, Heat Transfer & Phase Change Version 4.3b 12 Replies
Until 3.5a, there used to be nice flsave which would save fem structure as comsol's model file. Can somebody tell what is its counterpart in 4.x series? May be I missed something but looking into docs only highlighted mphload. Since comsol's model can no longer be saved even in a mat file using save command, I was wondering how to save results for post-processing?
In our case, we lost 5 hours of processing-work because of Windows automatical updates during the night. We weren't able to save or export our work. So, is there any way to save or export a model with matlab ?
Best regards
model.save('filename');
eg. model.save('d:\users\OSCsavetest');
(the 'model' is the object you create with command: model = ModelUtil.create('Model'); it could be other names)
with this command, it allows you to save you model object in m-file too
you can find more detail in documentation: LiveLinkForMATLABUsersGuide.pdf
I don't know if my answer is something you guys expected.
hope it is useful to you
Regards
Honghui
Thanx a lot Honghui
Best regards
Alex
Unfortunately, model = ModelUtil.load(<tag>, <filename>) is only for loading a .mph file.
Doing .mph to .m is easy (in COMSOL, File > Save as Model M-file...).
Doing .mph to model is easy (in MATLAB, see above)
Doing model to .mph is easy (in MATLAB, model.save(<filename>))
Doing model to .m is easy (in MATLAB, model.save(<filename>, 'm')
But how to do:
.m to .mph ???
or
.m to model ???
(NOTE: In COMSOL 4.1 there is no option to do a "File open" of a M-file directly)
I didn't try, hope it works
Matlab Script:
import com.comsol.model.*
import com.comsol.model.util.*
model.modelPath('N:\Projects\MicFEAModelingPrograms\COMSOL42\BumpedBP\Matlab\');
model.save('test')
I receive the error:
"Error using com.comsol.model.impl.ModelImpl/save
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Could not create temporary model file on server
Could not create temporary model file on server"
<stack info>
Any thoughts on what is causing this?
I don't know what the purpose of the modelPath property is, the documentation is mum on this. But as far as I can tell, it has no purpose.
However, the documentation does have this to say:
Use the function mphsave to save the model object linked to the MATLAB object model:
mphsave(model,'filename')
If the filename specified 'filename' [sic] does not provide a path the file is saved relatively to the local MATLAB path. The file extension determines which format to use (*.mph, *.m or *.java).
Alternatively you can use the save method:
If 'filename' does not provide a path the file is saved relatively to the local COMSOL server path.
So I guess in your case, you don't have write access to whatever the "local COMSOL server path" is. (On my machine, model.save() writes to [ComsolDir]\mli\startup for some reason.) I prefer to use mphsave() anyway, as the current Matlab working directory is usually the path I want to write to.
Thanks a lot.
I'm now using comsol4.3a and get the same error as yours. Have you figured out the reason for this error?
Thank you!
Suggested Content
- BLOG Solutions as Starting Point Values with LiveLink™ for MATLAB®
- KNOWLEDGE BASE COMSOL 6.1 macOS Apple Silicon Native Support
- KNOWLEDGE BASE COMSOL 6.0 macOS Apple Silicon Native (M1) Support
- BLOG Best Practice for Working with Model M-Files
- FORUM Saving simulated model as mat file in matlab, livelink
