Coupling back and forth between physics nodes
Posted 2016年12月8日 GMT+8 20:42 Heat Transfer & Phase Change, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.2 0 Replies
I'm creating a model where I want to couple back and forth between light diffusion (stationary Helmholtz equation) and bioheat transfer (time dependent). This to implement dynamic temperature changes in the optical parameters used for solving the Helmholtz equation.
One approach I have tried is to manually create two studies, and this works for the coupling of the two physics nodes, but it would be very time consuming to manually do this for every time step for longer study times. Instead I have tried to generate a parametric sweep, where ideally, for each step in the loop, I want to keep the last values of the previous solution as initial values for the next step, but I can't get it to work. I have looked at the panel, "Initial values of variables solved for", but I can't couple the same study step with itself (time dependent for example).
Is it possible to use a parametric sweep in my case, or is there another approach to use when coupling back and forth between physics nodes with two different types of studies (stationary and time dependent)?
Any suggestions and ideas are most wellcome
Thanks in advance
With kind regards
Hampus
Hello Hampus Mårtensson Jönsson
