Far field of dipole antenna on substrate
Dear COMSOL community
I try to model a nanodipole antenna on glass substrate , first I create a model for a nanodipole in air and the far field seems good to me ( the tours shape typical for dipole antenna ) , where the far field calculation is made by a surface surround the dipole and placed lamb/2 far away from the dipole.
Now I placed the dipole on the top of a glass substrate , while the far field domain this time will be half air and half substrate , unfortunately the shape of the far field seems to me incorrect , I read on the thread that the far field domain has to be homogeneous, but how to calculate the far field in the case of antenna placed on substrate
Thanks in advance
M.H.Elshorbagy
UCM , Spain
11 Replies Last Post 2017年3月28日 GMT+8 00:15
Posted: 9 years ago 2016年12月8日 GMT+8 23:40
You can try only select the air domain for the far field domain node. I am not sure if this is correct rigorously because in this way the far field calculation surface you should select is part of the PML inner surface. But you can try it and see if you can get the results you expect (maybe for some scattered angles, it is a good approximation).
Another way is that you put a plane above the dipole and a plane inside the substrate, then calculate the far field through the calculated fields on the plane. But in this way, you do the far field calculation by yourself.
If you really want to use comsol's far-field calculation. An idea is that 1.you save your near-field results.2,build another empty model (I mean no glass substrate) and put the near-field results into this model 3.The far field for this model is homogeneous now, so run it and you can get the far field results. This is a bit more complicated and you need to be careful about every step.
You can try only select the air domain for the far field domain node. I am not sure if this is correct rigorously because in this way the far field calculation surface you should select is part of the PML inner surface. But you can try it and see if you can get the results you expect (maybe for some scattered angles, it is a good approximation). Another way is that you put a plane above the dipole and a plane inside the substrate, then calculate the far field through the calculated fields on the plane. But in this way, you do the far field calculation by yourself. If you really want to use comsol's far-field calculation. An idea is that 1.you save your near-field results.2,build another empty model (I mean no glass substrate) and put the near-field results into this model 3.The far field for this model is homogeneous now, so run it and you can get the far field results. This is a bit more complicated and you need to be careful about every step.
Posted: 9 years ago 2016年12月8日 GMT+8 23:56
Dear Xu Xu
Thank you very much for your reply , I really appreciate it.
I understand from your reply that I have three choices to try :
-the first choice is to calculate the far field only in the air domain
-the second is to calculate it into two parts one in air and the second in substrate.
- The third one is to calculate the near field for the dipole while I have both air and substrate then use this field to calculate the far field
The first two choices can be done easily , but I still don't understand how to do the third one , do I will use the near field as background field for the far field calculation , or how to implement this near field data on the blank model to calculate the far field
Thanks in advance
Dear Xu Xu Thank you very much for your reply , I really appreciate it. I understand from your reply that I have three choices to try : -the first choice is to calculate the far field only in the air domain -the second is to calculate it into two parts one in air and the second in substrate. - The third one is to calculate the near field for the dipole while I have both air and substrate then use this field to calculate the far field The first two choices can be done easily , but I still don't understand how to do the third one , do I will use the near field as background field for the far field calculation , or how to implement this near field data on the blank model to calculate the far field Thanks in advance
Posted: 9 years ago 2016年12月9日 GMT+8 18:49
Hi all
I still don't trust the results that I have , does any one made this kind of calculations before
Thanks in advance
M.H.Elshorbagy
Hi all I still don't trust the results that I have , does any one made this kind of calculations before Thanks in advance M.H.Elshorbagy
Posted: 9 years ago 2017年3月16日 GMT+8 09:39
Hi M.H.
Not sure whether you have a solution yet, but what I might guess is that your current simulation is calculating the far-field distribution coming from the antenna and substrate combined. This means that, for instance, the antenna contribution will become smaller as your simulation domain gets larger and the scattered field is dominated by that from the 50% substrate.
If this is the problem, you might need to consider a way to isolate the scattered fields coming from just the antenna. An option could be to set up your simulation into two steps as per a superposition:
(1) create a first simulation step that calculates the total fields produced after your externally applied field is incident on the substrate without antenna. What you want from this simulation is the total fields in the volume/domain where your antenna would otherwise be located (i.e. if it wasn't removed from this simulation step).
(2) create a second simulation step to calculate the scattered field for the complete antenna + substrate, but you instead now specify the externally applied field as the total fields calculated in (1), and only in the domain of the antenna. Effectively, the antenna alone will now behave as the source of this simulation. This simulation should give you a far-field pattern that comes a bit more exclusively from just the antenna, and will hopefully look like the dipole on substrate far-field pattern you were looking for. A similar approach for this step could be to use no externally applied fields, and instead use a volume polarization distribution to impose the applied fields from (1) in (2).
Finally, I suspect the above approach may only work in frequency domain, but a first order approximation could also be done in time domain by calculating the total fields both with and without antenna, then taking their difference to find the approximate scattered field and subsequent far field profile. This won't work if the substrate-antenna interaction is too strong.
Hopefully this is relevant to your particular issue!
Cheers,
Ben
Hi M.H. Not sure whether you have a solution yet, but what I might guess is that your current simulation is calculating the far-field distribution coming from the antenna and substrate combined. This means that, for instance, the antenna contribution will become smaller as your simulation domain gets larger and the scattered field is dominated by that from the 50% substrate. If this is the problem, you might need to consider a way to isolate the scattered fields coming from just the antenna. An option could be to set up your simulation into two steps as per a superposition: (1) create a first simulation step that calculates the total fields produced after your externally applied field is incident on the substrate without antenna. What you want from this simulation is the total fields in the volume/domain where your antenna would otherwise be located (i.e. if it wasn't removed from this simulation step). (2) create a second simulation step to calculate the scattered field for the complete antenna + substrate, but you instead now specify the externally applied field as the total fields calculated in (1), and only in the domain of the antenna. Effectively, the antenna alone will now behave as the source of this simulation. This simulation should give you a far-field pattern that comes a bit more exclusively from just the antenna, and will hopefully look like the dipole on substrate far-field pattern you were looking for. A similar approach for this step could be to use no externally applied fields, and instead use a volume polarization distribution to impose the applied fields from (1) in (2). Finally, I suspect the above approach may only work in frequency domain, but a first order approximation could also be done in time domain by calculating the total fields both with and without antenna, then taking their difference to find the approximate scattered field and subsequent far field profile. This won't work if the substrate-antenna interaction is too strong. Hopefully this is relevant to your particular issue! Cheers, Ben
Posted: 9 years ago 2017年3月16日 GMT+8 23:26
Dear Dr Ben
Thank you for your kind reply , I really appreciate your help . In fact I set several contacts with COMSOL people and we try your solution , but I didn't trust the result , while they told me that the equation that used by comsol to calculate the far-field is assuming that the resonant element is compelety embdded in air
while we have a different situation of two media one above the element (air) and another below it ( substrate ).
We still work on the problem , to set a solution for the far field in a non homogeneous media or multi- layer systems
I really appreciate you help and still need any experience or information to share
Thanks in advance
M.H.Elshorbagy
UCM Spain
Dear Dr Ben Thank you for your kind reply , I really appreciate your help . In fact I set several contacts with COMSOL people and we try your solution , but I didn't trust the result , while they told me that the equation that used by comsol to calculate the far-field is assuming that the resonant element is compelety embdded in air while we have a different situation of two media one above the element (air) and another below it ( substrate ). We still work on the problem , to set a solution for the far field in a non homogeneous media or multi- layer systems I really appreciate you help and still need any experience or information to share Thanks in advance M.H.Elshorbagy UCM Spain
Posted: 9 years ago 2017年3月23日 GMT+8 00:06
I see there are a few other posts where it is concluded that the far field domain only works correctly for a homogeneous domain that surrounds the scatterer. However, I had a quick look into the accuracy of using two far field domains to calculate far field distributions from an 'antenna on substrate' model, and it didn't look too bad. Specifically, with my antenna positioned at the origin, I compared the far field calculation to the radial component of the time averaged Poynting vector at a wavelength away from my antenna.
Case 1: far field calculation
Two far field domains: one for each homogeneous hemisphere enclosing my antenna on substrate, with scattered field from the antenna calculated as per my first post. The scattered simulation is called ewfd2, and I called the two far field results Efar2 and Efar3, I then plot a 3D far field of the quantity:
(abs(ewfd2.Efar2x+ewfd2.Efar3x)^2+abs(ewfd2.Efar2y+ewfd2.Efar3y)^2+abs(ewfd2.Efar2z+ewfd2.Efar3z)^2)^0.5
Case 2: outgoing time averaged Poynting vector
I have a sufficiently large simulation domain to be able to fit a one wavelength radius sphere (radius = R) around my antenna.
I then make an 3D plot group with an isosurface of the quantity:
"(x^2+y^2+z^2)/(R^2), with levels at value 1.
This is my one wavelength radius sphere. To this isosurface I add first a color expression:
(ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R
Then I add second a deformation expression to the isosurface:
x component: (ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R*(x/R)
y component: (ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R*(y/R)
z component: (ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R*(z/R)
Provided one wavelength is sufficient to reach a far field regime (where 1/r decay dominates the E and and H-field), this should be the correct far field from the antenna
While I can't seem to attach pictures of these, I will say that there are quantitative differences between the two cases, but qualitatively they look similar (same general shape). Actually, the main issue is the Poynting vector ("true") calculation, which seems to have discontinuities imprinted in the radiation pattern from the mesh, but hopefully (*maybe) this would improve if I did denser meshing of the radius=R sphere.
Ben
I see there are a few other posts where it is concluded that the far field domain only works correctly for a homogeneous domain that surrounds the scatterer. However, I had a quick look into the accuracy of using two far field domains to calculate far field distributions from an 'antenna on substrate' model, and it didn't look too bad. Specifically, with my antenna positioned at the origin, I compared the far field calculation to the radial component of the time averaged Poynting vector at a wavelength away from my antenna. Case 1: far field calculation Two far field domains: one for each homogeneous hemisphere enclosing my antenna on substrate, with scattered field from the antenna calculated as per my first post. The scattered simulation is called ewfd2, and I called the two far field results Efar2 and Efar3, I then plot a 3D far field of the quantity: (abs(ewfd2.Efar2x+ewfd2.Efar3x)^2+abs(ewfd2.Efar2y+ewfd2.Efar3y)^2+abs(ewfd2.Efar2z+ewfd2.Efar3z)^2)^0.5 Case 2: outgoing time averaged Poynting vector I have a sufficiently large simulation domain to be able to fit a one wavelength radius sphere (radius = R) around my antenna. I then make an 3D plot group with an isosurface of the quantity: "(x^2+y^2+z^2)/(R^2), with levels at value 1. This is my one wavelength radius sphere. To this isosurface I add first a color expression: (ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R Then I add second a deformation expression to the isosurface: x component: (ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R*(x/R) y component: (ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R*(y/R) z component: (ewfd2.Poavx*x+ewfd2.Poavy*y+ewfd2.Poavz*z)/R*(z/R) Provided one wavelength is sufficient to reach a far field regime (where 1/r decay dominates the E and and H-field), this should be the correct far field from the antenna While I can't seem to attach pictures of these, I will say that there are quantitative differences between the two cases, but qualitatively they look similar (same general shape). Actually, the main issue is the Poynting vector ("true") calculation, which seems to have discontinuities imprinted in the radiation pattern from the mesh, but hopefully (*maybe) this would improve if I did denser meshing of the radius=R sphere. Ben
Posted: 9 years ago 2017年3月23日 GMT+8 00:33
Dear Dr Ben
First I would like to thank you for your kind help , I really appreciate it.
Then Your calculations and suggestions is very interesting to me , in fact it will help to much. We keep working on the problem until having a good results using several approaches. So if possible let us keep in touch I will let you knew the results .
Thanks to much ,
Sincerely
M.H.Elshorbagy
Dear Dr Ben First I would like to thank you for your kind help , I really appreciate it. Then Your calculations and suggestions is very interesting to me , in fact it will help to much. We keep working on the problem until having a good results using several approaches. So if possible let us keep in touch I will let you knew the results . Thanks to much , Sincerely M.H.Elshorbagy
Konstantinos Tsoukalas
Posted: 8 years ago 2017年3月27日 GMT+8 21:26
I am working in a similar problem trying to calculate the far field in an inhomogeneous medium.
I do not think that you can use the Comsol far field calculator since the method works only in homogeneous media. What you could do though is calculate the near field of your antenna in
the homogeneous area in Comsol and then follow the techniques in this paper : DOI: 10.1021/acsphotonics.5b00559 . You will probably need to export the field to MatLab
to do that.
Best of luck and let me know about your progress.
Hi, I am working in a similar problem trying to calculate the far field in an inhomogeneous medium. I do not think that you can use the Comsol far field calculator since the method works only in homogeneous media. What you could do though is calculate the near field of your antenna in the homogeneous area in Comsol and then follow the techniques in this paper : DOI: 10.1021/acsphotonics.5b00559 . You will probably need to export the field to MatLab to do that. Best of luck and let me know about your progress.
Posted: 8 years ago 2017年3月27日 GMT+8 22:45
Dear Konstantinos
Thank you very much for your kind response and help , i really appreciate it , I will try it and let you knew the results
Thanks too much
M.H.Elshorbagy
UCM Spain
Dear Konstantinos Thank you very much for your kind response and help , i really appreciate it , I will try it and let you knew the results Thanks too much M.H.Elshorbagy UCM Spain
Posted: 8 years ago 2017年3月27日 GMT+8 23:40
Just to make sure that you saw this reference in the paper, I put it here.
www.lp2n.institutoptique.fr/Membres-Services/Responsables-d-equipe/LALANNE-Philippe
They have Matlab code that works directly with Comsol.
Just to make sure that you saw this reference in the paper, I put it here. https://www.lp2n.institutoptique.fr/Membres-Services/Responsables-d-equipe/LALANNE-Philippe They have Matlab code that works directly with Comsol.
Posted: 8 years ago 2017年3月28日 GMT+8 00:15
Dear Dr Konstantinos
Thanks too much for the Link
Sincerely
M.H Elshorbagy
Dear Dr Konstantinos Thanks too much for the Link Sincerely M.H Elshorbagy
