Jeff Hiller
COMSOL Employee
7 years ago
2017年3月13日 GMT-4 08:08
Hello Brian,
Have you tried creating a Cut Point 3D data set and using that for your post processing?
Hello Brian,
7 years ago
2017年3月15日 GMT-4 14:08
I'm looking for something like this:
www.comsol.com/community/forums/general/thread/35590/
where I can input a series of x,y and z coordinates and get the values that way.
I tried to do two things to facilitate this: one, what was mentioned in that with the scatter volume (but I needed to input a radius, not sure what that was about) and also through exporting a grid of points and finding the closest value in the grid to the actual coordinate I have, but I wasn't able to export a fine enough grid for what I wanted due to memory problems.
Ideally I want to get values at whatever x,y,z coordinate I want. If I have to do it manually I will, albeit it will be a long annoying process. Is there a way to do this?
Thanks!
https://www.comsol.com/community/forums/general/thread/35590/
Thanks!
Jeff Hiller
COMSOL Employee
7 years ago
2017年3月15日 GMT-4 14:39
Hi Brian,
It sounds like you are after a Cut Point 3D data set.
If the issue is that you have many such points, as suggested by the last sentence, then you could create an app to read the coordinates for all the points from file and automate the process of creating the data sets and evaluating your field (pressure) at those points.
Or you could do essentially the same via MATLAB if your license includes LiveLink for MATLAB.
I am sure there are a bunch of other ways.
Hi Brian,
Gunnar Andersson
COMSOL Employee
7 years ago
2017年3月16日 GMT-4 03:33
If you have many (x, y, z)-triplets in a file, then I suggest the following approach:
- Create a 3D Cut Point data set.
- Set Entry method =From file.
- Browse to the file containing your points. The file format is assumed to be one line for each point. If your file has some other format, then you have to preprocess it in some external program.
- Results > Export: Create a Data export.
- Select the cut point data set created above.
- Choose the expression(s) to evaluate and browse to an output file. Click on Export.
An alternative is to use a Results > Derived Values > Point Evalution feature. Then you see the results in a table in the GUI. This approach works for a small to moderate number of points, but for a large number of points it becomes unwieldy.
[QUOTE]
[/QUOTE]
7 years ago
2017年3月28日 GMT-4 12:46
Hello, sorry for responding late to this, I was at a conference the past week,
The former worked perfectly, thanks!
