Import a parasolid file from solid works
Posted 2011年2月7日 GMT+8 23:53 9 Replies
I would like to know if it is possible to import a parasolid file from SolidWorks to COMSOL. What are the steps? and how can I mesh a imported file?
Regards and thanks in advance
COMSOL reads directly parasolid files, it's "just" to import the CAD
I'll try to explain a little bit my problem this time.
I'm using a .stl file and trying to import it to a 3.5a COMSOL version. It spends a lot of time to import it and once it has finished a warning appears. The figure is a group of lines, is not a solid anymore.
Do you have any idea?
well "stl" is no full 3D grpahics file format, it's a pseudi 2D layer format used for 3D printing, I'm not sure 3.5a has a translator, this requires that your volume is recomposed, a tedious task. But if you can make a STL file mostly you can also make a true 3D .X_T file and that is far easier to use in COMSOL (also 3.5 ;)
I've tried with a simplest structure and a .X_T format and I finally meshed my problem.
However when I refine my structure (I add more faces to get an approach to a cylinder) in solidworks I have problems to mesh the structure once it has been imported.
I hope you guide me with this problem.
Regards
then why not use cylinders, these are geometrical shapes known to COMSOL.
And when you talk about facets, is this the geometrical display rendering ? or the way you approximate a cylinder by small sections of a polygone ?
I've already tryed with cylinders however I could not find the way to mesh them properly. In fact the error that I get when mesh the structure is the following:
Error: 4028
Failed to generate mesh for face.
- Face: 1
Failed to insert point.
- s1 value: 0
- s2 value: 1
An invalid cavity was detected.
Javier
this mainly means you do not have a clean geometry,some small overlaps (perhaps in the 1-10 um siz region, o siver faces etc., check your geometry, are all domains clean ? and separate, with well defined common boundaries
I'll try to explain my point. I'm working with a conductor espiral coil generated in solidworks. I've being trying to import a cylindrical wire coil in a parasolid format and after several messages like the following:
Error: 4028
- Face: 2
- s1 value: 1
- s2 value: 1
I decided to try with a square corss section wire coil and I succeed meching the structure and solving the problem. I decide to go forward and try with more complex geometries of wire cross section however I could not obtain any result when meshing and I came back to similar errors that presented above.
I hope this clarify my point.
regards,
not fully apart that "cavities" meen for me nested domains or silfer faces that are badly interpreted. you can check surface "2" in the corner where the surface tangeant s1=s2=1.
you know in v4.1 you can geerate spirals also in COMSOL
