error while solving..
Posted 2017年4月9日 GMT+8 08:08 Heat Transfer & Phase Change, Porous Media Flow, Chemical Reaction Engineering Version 5.0 1 Reply
I am using v5.0 and I am having this error. My model solves for heat transfer, fluid flow, and vapor transport. Any help would be very appreciated.
Thanks!
Jessica
Division by zero.
- Function: /
- Expression: nojac(((1.4142135623730951^(1-shapeorder(comp1.cv)))*max((((sqrt(comp1.tds.gugijgu_cv)*((0.5*abs(comp1.tds.Res_cv))*comp1.tds.xiu_cv))/((comp1.tds.gugijgu_cv+((h^2)*sqrt(eps)))*comp1.tds.epsilon_p))-(((comp1.tds.Res_cv^2)*comp1.tds.tauScCwd_cv)/(eps+(comp1.tds.gugijgu_cv*comp1.tds.epsilon_p)))),0)))
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.tds.crosswind@VDN${test@92}@VDN$comp1.cvz
- Defined as: (((-nojac(((1.4142135623730951^(1-shapeorder(comp1.cv)))*max((((sqrt(comp1.tds.gugijgu_cv)*((0.5*abs(comp1.tds.Res_cv))*comp1.tds.xiu_cv))/((comp1.tds.gugijgu_cv+((h^2)*sqrt(eps)))*comp1.tds.epsilon_p))-(((comp1.tds.Res_cv^2)*comp1.tds.tauScCwd_cv)/(eps+(comp1.tds.gugijgu_cv*comp1.tds.epsilon_p)))),0))))*comp1.tds.epsilon_p)*comp1.tds.gijyz)
- Expression: d(d((comp1.tds.crosswind*(comp1.isScalingSystemDomain==0))*(dvol),{test@92}),comp1.cvz)
- Feature: Time-Dependent Solver 1 (sol1/t1)
Thanks!
Jessica
Division by zero.
- Function: /
1 Reply Last Post 2017年4月10日 GMT+8 11:14
