Lars Gregersen
COMSOL Employee
9 years ago
2017年4月28日 GMT+8 23:34
Hi Vladimir
It works for me.
What version of Comsol are you using?
What is the exact error message?
Lars Gregersen
Comsol Denmark
Hi Vladimir
It works for me.
Lars Gregersen
Comsol Denmark
9 years ago
2017年4月29日 GMT+8 21:27
Updated:
9 years ago
Hi Lars,
I'm using COMSOL 5.2 (version: 220).
Here is the code:
pd=mpheval(model,'d(es.normE*es.normE,x) d(es.normE*es.normE,y)','selection','pointi');
Here is the message:
Error using mpheval (line 328)
mpheval (174): Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Syntax error in expression
(rethrown as com.comsol.util.exceptions.FlException)
Erreur de syntaxe dans une expression.
- Expression: d(es.normE*es.normE,x) d(es.normE*es.normE,y)
- Sous-expression: d(es.normE*
- Position: 2
Vladimir
Hi Lars,
Here is the code:
Exception:
- Position: 2
Vladimir
Lars Gregersen
COMSOL Employee
9 years ago
2017年5月2日 GMT+8 15:15
You are doing it wrong ;-)
If you wish to evaluate more than one expression you should put them in a cell array:
pd=mpheval(model, {'d(es.normE*es.normE,x)' 'd(es.normE*es.normE,y)'}, 'selection', 'pointi');
Lars Gregersen
Comsol Denmark
Lars Gregersen
Comsol Denmark
9 years ago
2017年5月2日 GMT+8 17:15
Ok, i'm confused because this command works well:
pd=mpheval(model,'V es.normE es.Ex es.Ey','selection','pointi');
I have another question. When i evaluate with pointi defined as follow:
model.selection.create('pointi','Ball');
model.selection('pointi').set('posx','L/2');
model.selection('pointi').set('r','8');
model.selection('pointi').set('entitydim',0);
model.selection('pointi').set('condition','inside');
this select only, if any, the geometrical point inside the Ball.
If i want to create a selection on all the mesh node inside pointi, should i create firstly a geometrical domain according to pointi ?
Lars Gregersen
COMSOL Employee
8 years ago
2017年5月19日 GMT+8 16:11
Hi Vladimir
Yes, this is a feature, but this feature only works with simple expressions and not when you are using functions with multiple parameters.
Selections work on the geometry level. Why do you need a selection of the interior mesh points?
Lars Gregersen
Comsol Denmark
Hi Vladimir
[QUOTE]
[/QUOTE]
Lars Gregersen
Comsol Denmark
