Getting data from nongeometric parameter sweeps
Posted 2017年5月5日 GMT+8 01:18 Version 5.2a 0 Replies
I have a model where I am sweeping the wavelength of light that is being excited, as well as a geometrical parameter. I am coupling that model with a thermal model that uses the Qh parameter of the electromagnetic waves model to generate heat and then do a thermal model from there.
What I want to do is then select a particular domain, do a "Volume Maximum" calculation on that domain only, and output the maximum temperature in that domain to a table where both parameters are the first two columns and the temperature is the third.
However, when I try to do this, the wavelength parameter does not seem to "apply" to the sweep. It has a column, but all of its values are listed as 0, and it only sweeps through the number of values in the geometrical parameter. It has something to do with the wavelength I am fairly certain because if I switch my parametric sweep to only geometrical parameters it works fine.
It's somewhat infuriating because I can plot the solutions with all the wavelengths, so the data is there, it's just that the derived parameter function doesn't work.
Also, I'd like to attach a file I have with a trivial geometry simulation, but when I try I seem to get a "file extension error". Any ideas on how to do that as well so it's easier to see what's going on?
Hello Daniel Klemme
